Old 01-24-2010, 06:17 PM
Zekery360 Zekery360 is offline
Vehicle: 2002 Dodge Ram
Color: Bright Red
Zekery360 is on a distinguished road
Default Electric Fan experience anyone?
Me and a couple buddies decided electric fans would be the way to go for our pickups, however I am not sure where to get the fan. I hear you can take them out of many cars with a 3.8L, but I am not really sure. If anyone could help point me towards some fans I could take out of cars at a junkyard, that would be great. I don't feel like paying $600 for a e-fan kit if I can do it for $100.
Thanks guys!
Old 01-24-2010, 06:24 PM
I'd measure the area you have available to mount a fan. Then start measuring fans in the junkyard. Take an extra battery with you to test the fans. I've heard the same thing about the GM 3.8L engined cars and the fans but I've never tested it out.
I think a lot of junkyard fans can be mounted on the back side of the stock radiator...you just have to make sure you have adequate depth and up/down, side to side dimensions to work with.
Old 01-24-2010, 06:49 PM
Rep:1845
Don't mount the fan with the plastic touching the radiator fins. You'll nee some sort of padding of a little space in between to keep the fan vibration from rubbing a hole in the radiator.
Old 01-25-2010, 10:39 AM
34blazer 34blazer is offline
Vehicle: 1997 Dodge Ram
Trim Level: SS/T
Color: black/silver stripes
34blazer is on a distinguished road
right now i have an Efan from a mid 90's T-bird 3.8. not liking it at all, it draws too much current for my 30 amp relay. going to the pullapart to get the dual fan setup off a ford contour or something like that.
Old 01-25-2010, 11:42 PM
Plainbroke Plainbroke is offline
Plainbroke is on a distinguished road
Taurus or Sables, and Continetals, that had the 3.8L seem to be the most popular..
Old 02-04-2010, 01:31 AM
graphicjunkie's Avatar
graphicjunkie graphicjunkie is offline
Vehicle: 2003 Ram 1500 5.9L
graphicjunkie is on a distinguished road
What else is needed to make these work? I don't see people just running a switch to the cab. ?
2003 Laramie 1500 - 5.9L
Volant cai - Aero exhaust - Ride Rite - leveled
Old 02-04-2010, 08:33 AM
Trim Level: SS/T
you can buy an efan t-stat and relay kit from just about any auto parts store. they are adjustable to whatever temp you want the fan to run at
Old 03-22-2010, 07:00 PM
rustyolred's Avatar
rustyolred rustyolred is offline
Vehicle: 1997 Ram 1500 ext cab 4x4
Trim Level: Laramie SLT
Rep:20
rustyolred is on a distinguished road
Send a message via AIM to rustyolred
My truck has a e-fan already installed by the po. It is not wired. It has 4 wires. 2 are hooked up to a temp switch/sending unit in the radiator. Can anyone give any heads up on how to wire this thing. It is a 14" unit. I am wanting to get rid of the belt driven viscous clutch and fan. Is this a good idea?
Rusty
Old 03-22-2010, 09:06 PM
Color: Bright Red
Getting rid of the belt driven fan is a good idea, but I can't help as far as wiring goes. Most temp. controllers come with wiring diagrams for you to follow and get everything hooked up. Beyond that, the fan itself pretty much just needs 12 volts and ground.
Old 03-22-2010, 09:45 PM
rustyolred's Avatar
Rep:20
well it came with the truck and no instructions were included.
anyone?
Rusty
