Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Old 01-25-2010, 06:30 PM
black06 black06 is offline
black06 is on a distinguished road
Default Help with lift kits!
Hi, I have an 06 RAM 1500 Sport 4x4 QC, and i want to go with the 6'' fabtech suspension lift along with a 3'' inch body lift, i talked to a guy from performance lifts.com, and he said that i can install both kits with nothing else required, but wont i need some steering components or something? or something for my driveshaft? its cause i dont think i can lift it 9 inches total without touching my driveshaft right ? i want to stick some 37's on there aswell and i wanted to know if i got both kits and installed them out of the box i could just drive away after its done? nothing else needed? thanks
Old 01-25-2010, 06:35 PM
Doing the 3" body lift doesn't effect the driveshaft . Your lifting the body off the frame . 6" suspension lift ? If they say your fine , then go with it .
Old 01-25-2010, 07:08 PM
yeepjeep's Avatar
yeepjeep yeepjeep is offline
Vehicle: 2010 Ram
Trim Level: Sport, with R/T Hood
Color: Inferno Red
yeepjeep is on a distinguished road
Since your truck is long enough you shouldnt need a new shaft after a 6" lift. As for the body lift if you can avoid doing it then by all means dont put it in, as you will have a nasty 3" gap between your frame rails and the cab, plus a slighty accident or even some harsh roads can be enough for the cab to shift. 3" space between body and frame being secured by a grade 8 bolt doesnt take much to shif tthe body, stick to an inch or 1 1/2" BL at most.
Old 01-27-2010, 09:06 PM
age525's Avatar
age525 age525 is offline
Vehicle: 2006 Dodge Ram 1500
Rep:91
age525 will become famous soon enough
I think that you may need to lengthen the steering column and you probably need a wheel alignment afterwards also.
S&B Cold Air Intake, American Racing Headers, DB Performance Cat Back Exhaust, Recon LED Taillights, Bilstein 5100's, Toyo Open Country AT 2, Diablosport Predator, Recon Line of Fire, JL Audio 10W3 StealthBox, Alpine iDA-X305s Head Unit, Detroit TrueTrac
Old 01-30-2010, 12:41 AM
yeepjeep's Avatar
Vehicle: 2010 Ram
Color: Inferno Red
Possibly might need to lengthen the coloumn witht he BL, but most full lifts will come with proper steering corrections light a drop pitman arm etc to correct that, but yes an alignment is a must after any type of spring/coil lift
Old 02-03-2010, 02:11 AM
I Hemi I I Hemi I is offline
Vehicle: 2004 Dodge Ram 1500
Trim Level: SLT 4x4
I Hemi I is on a distinguished road
i know this doesnt answer your question but, I personally would not get the 3" body lift. From personal experience I have just found it to be unsatisfying. I think that a 6" suspension lift is plenty and will look great. The body lift seems to just move things to make it harder, such as the engine will drop in the hood, nerf bars will have to be specially made, and a couple other little annoying things. 6" suspension is plenty for almost any street legal wheels. So in my opinion, I'd say just go with that.
Old 02-03-2010, 05:18 PM
foxcrazy90's Avatar
foxcrazy90 foxcrazy90 is offline
Vehicle: 2008 dodge ram 1500
Color: electric blue pearlcoat
Rep:584
foxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to all
you have to admit that would look sick!!!! 9" lift WOW!!!!
NEIL KELLEY
2008 ram 1500 bighorn 4x4
2 1/2 level lift--hella 500ff grill lights--17x9 centerline grizzly-305-70-17 nitto terra grapplers--front air valance removed--tinted windows--custom audio system clarion vz401 head unit--pioneer 4channel amp and class D mono amp--memphis mclass door speakers--clarion dash speakers--kicker subs
Old 02-03-2010, 09:04 PM
sablefish's Avatar
sablefish sablefish is offline
Vehicle: 2013 ram sport
Trim Level: sport
Color: red
Rep:78
sablefish will become famous soon enough
This is my cousins 2008 diesel 3500 Ram. He has 41" tires for sure and I think it is a 10" lift to fit them ( no body lift on truck just suspention )
2013 ram sport, 8 speed. pace edwards full metal jack rabbit tonneau, bed slide 1500cg bedslide, husky weatherbeaters
Old 02-03-2010, 11:18 PM
Awesome looking ride . Thanks for the pic . Rep for that .
Old 02-04-2010, 07:17 PM
TrailerTrash's Avatar
TrailerTrash TrailerTrash is offline
Vehicle: 2009 2500 4x4
Color: Navy blue
TrailerTrash is on a distinguished road
Dont get the body lift, the gap it creats looks bad.
Do or do not, there is no try.
