Changed rear diff fluid with 80w90. now what? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Old 01-25-2010, 07:35 PM
cnshough cnshough is offline
cnshough is on a distinguished road
Default Changed rear diff fluid with 80w90. now what?
Took my 05 4x4 to have the rear differential fluid changed to hopefully stop the infamous rear end shudder. It worked, but the lube place used a synthetic 80w90 gear oil. Am I gonna have a problem because they didn't use the 75w140 like the manual calls for or will It be ok for another 15k miles?
Old 01-25-2010, 07:43 PM
What do you have a 1500 , 2500 , 3500 ?
Old 01-25-2010, 07:52 PM
Resident Technician
Rep:1915
I'm guessing they didn't use synthetic either. If you have limited slip, did they put in an additive for it? If your truck is a 1500 then they put in the wrong lube and I wouldn't leave it in there because it's a significantly lighter oil.
Old 01-25-2010, 08:23 PM
1500. Asked them when I called to get a price if they had anything with the limited slip additive. He said yes, the synthetic it takes has it in It. The description on the Invoice said synthetic 80w90.
Old 01-25-2010, 08:33 PM
What motor do you have ? Checking something for ya .
Old 01-25-2010, 09:24 PM
Resident Technician
Rep:1915
Never heard of any synthetic gear oil with additive in it already.
