Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Old 01-18-2010, 03:43 PM
brandonterrill's Avatar
brandonterrill brandonterrill is offline
Gender: Not Specified
Vehicle: 1994 Dodge Ram 1500
Trim Level: ram single cab
brandonterrill is on a distinguished road
Default Oil filter help
my oil filter is completely destroyed pretty much to the point where all you see is what threads into the block i guess youd say i was wondering is there a way to remove the threaded rod the oil filter treads to, like a hex nut and if so what else comes with it (also any way to get the oil filter off i tried the screw driver and it just ripped it apart)
Old 01-18-2010, 03:48 PM
wvcoolvinilla wvcoolvinilla is offline
Vehicle: 2011 Ram 1500 Outdoorsman 4x4
Trim Level: Outdoorsman - Rambox
Color: Black Crystal - Gray
Rep:83
wvcoolvinilla will become famous soon enough
can you get a strap type pipe wrench on it?
Old 01-18-2010, 04:07 PM
nah my dude its like completely like fu*ked like its to the point where you can see the holes that belong imside the oil filter
Old 01-18-2010, 04:16 PM
Rep:83
If the steel ring that reside next to the block is still there, there is still hope.. you may be at the point you need a hammer and a chissel
Old 01-18-2010, 04:24 PM
ive been trying a hammer and a flat head
Old 01-18-2010, 04:33 PM
Rep:1909
Try something like this and get it as close to the block as possible. These aren't expensive and can be had at most parts stores.
Old 01-20-2010, 12:52 PM
stray dog's Avatar
stray dog stray dog is offline
Vehicle: 99 ram 1500
Trim Level: custom
Color: grey/silver
Rep:20
stray dog is on a distinguished road
this happened to me a few changes ago,had to tear the fliter completly apart i was using a hammer,punch set and vise grips.if you can bend the lip of the base of the fliter you could get the vise grips a may be able to unscrew it that way,or just keep working on that chisel, make sure not to dick up the holes on the block and if you can lift the front end up on some jack stands, it'll give you more room to swear loudly... good luck,let us know how it goes.
No Quarter
Old 01-21-2010, 03:08 PM
SgtMajBilly's Avatar
SgtMajBilly SgtMajBilly is offline
Vehicle: 2002 Dodge Ram 1500
Trim Level: SLT Quad 4x4
Color: Grey
SgtMajBilly is on a distinguished road
If you can get a set of filter pliers in there, that may be what you need. Grip the filter near the boss, hold tight and spin. Another method includes carefully inserting a long shaft screwdriver through the filter and use the handle as leverage to spin it off.
2002 Dodge Ram 1500 SLT Quad 4x4
2008 Dodge Nitro 4x4
Old 01-21-2010, 05:22 PM
MightyBlueRam's Avatar
Trim Level: Laramie 4x2
Color: Blue Streak Pearl Coat
Rep:435
I'm just wondering how your filter got this messed up?
Old 01-23-2010, 03:48 AM
stray dog's Avatar
Trim Level: custom
Color: grey/silver
Rep:20
well like i said it happed to me before, i got those pliers and they didnt help much. the best i could figure is it was to long since the last oil change and the filter heated up and expanded, may have weld to the block a bit
No Quarter
