Alignment specs? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 01-26-2010, 11:39 AM
txhemi's Avatar
txhemi txhemi is offline
Vehicle: 2008 Quad Cab 1500 2WD
Trim Level: SLT Lone Star
Color: Mineral Gray
Rep:268
txhemi is a jewel in the roughtxhemi is a jewel in the roughtxhemi is a jewel in the rough
Default Alignment specs?
Anyone know the specs or know where I can find the specs for my 08 qc 2wd with 3" lifting spindles? The truck has been to the alignment shop 4 times since last Monday and it still won't go straight. Apparently the lift spindles change the geometery of the suspension so the factory specs don't work. The shop said if I can get the specs for the lift, they will tune it to those specs. Thanks and any help would be greatly appreciated?
Old 01-26-2010, 12:06 PM
Resident Technician
Rep:1915
Any alignment man worth his salt can make one go straight even without factory specs. Is it pulling the same direction each time?
Old 01-26-2010, 12:09 PM
txhemi's Avatar
Color: Mineral Gray
Rep:268
Yes sir, it pulls right. They said without a spec sheet of some sort, they can't just do trial and error.
Old 01-26-2010, 12:18 PM
Resident Technician
Rep:1915
It's not trial and error, it's geometry. What all was done when the spindles were installed? Bigger tires or anything like that? Was it pulling, even a little, before the spindles went on?
Old 01-26-2010, 12:22 PM
txhemi's Avatar
Color: Mineral Gray
Rep:268
It was rolling perfectly straight before the spindles went on. The spindles were the only things done in the front, lift shackles were installed in the back. I've told the shop to loosen the right and tighten the left just a hair, but they won't do anything without a spec sheet. I guess this is what I get for going to a chain instead of someone independent.
Old 01-26-2010, 12:30 PM
Resident Technician
Rep:1915
Did you get a spec sheet from them after the alignment was done? I'd love to see the numbers.
Old 01-26-2010, 01:21 PM
txhemi's Avatar
Color: Mineral Gray
Rep:268
Ask and you shall recieve. The first one is from the first attempt and the second one is from the last attempt. Let me know if you can see the numbers well enough.
Old 01-26-2010, 02:10 PM
Resident Technician
Rep:1915
It'sn pretty clear why it pulled after the first alignment. Negative camber and less positive caster on the right side pretty much ensured that and it goes completely opposite the factory specs which are set to counter a pull to the right.
Left camber...+.10 deg
Right camber...-.10 deg
Cross camber...+.20 deg
Left caster...+3.50 deg
Right caster...+3.90 deg
Cross caster...-.40 deg
Left toe...+.18 deg
Right toe...+.18 deg
Total toe...+.38 deg
These are the factory preferred settings for the '08 1500, both 2WD and 4WD. If they get those right it should make a difference.
Old 01-26-2010, 02:53 PM
txhemi's Avatar
Color: Mineral Gray
Rep:268
Great, thanks! I'll see if they can get to those numbers for me.
Old 01-26-2010, 03:27 PM
Resident Technician
Rep:1915
A decent alignment man would know what those numbers mean. I'm guessing that the guy doing yours is some flunkie off the street that figures as long as the numbers are green, everything's ok. Wrong answer! I keep a tailors style measuring tape for checking tire circumferences because a difference there can also cause a pull.
