Old 05-11-2010, 11:26 AM
Yes, Ma'am...Right Away, Ma'am...
I will def be takin' pics during the install so you can see how it's done. This will be easy (my fingers are crossed) and if we run into any trouble, my LX buds are a pretty bright group and we'll figure it out. If I have correctly done my due diligence and analysis in selecting the right parts, no issues should come up.
But I don't expect to run into anything we haven't run into before doing audio and other mods to the LX cars.
But, no beer for the crew until the work is done and everything works.
Old 05-11-2010, 11:31 AM
trx4's Avatar
trx4 trx4 is offline
Vehicle: 2006 Q-Cab
Trim Level: SLT TRX4
Rep:45
trx4 is on a distinguished road
They sound real good MadDog look good to
Old 05-12-2010, 11:24 PM
OK, so today after work I decided to put the dash speakers in. It's easy and took all of 15 minutes to do. This is on a 2007 Ram and will be the same process on any of the Gen 3 trucks. It will also be similar on other generation trucks.
Tools needed:
A trim stick or soft plastic panel tool
Small ratchet & 9/32nd socket
First, take your trim stick or panel tool and gently pry up under the corner of the defroster panel at the top of the dash:
Continue popping the panel out of the spring clip sockets all the way to the other side of the cab.
Now, take the edge of the panel and pull it towards the back of the cab. There are at least four plastic sockets that the leading edge slips into at the base of the windshield.
And, the panel is out. Set it aside, then look at your speakers.
You may have two or possibly three speakers under the panel. The two outside corner units are 3.5" size speakers. The one in the middle, if you have it (Infinity systems have them for sure) you will also pull it out. I pulled my center speaker some time ago.
Time to pull the speaker. They are held in place with two screws that look a lot like self-tapping drywall screws.
Time for the ratchet and socket. You can also use a very short phillips head screwdriver. Remove the screws and set them aside. You'll need them later to install the new units.
When you have removed the screws, lift the speaker straight up out of the hole. On the back side you'll find the wiring harness and connector attached to the speaker. Push in the little white tab in the connect slot on the speaker and pull the connector out.
Here's the wiring harness and stock connector, ready for the new speaker.
I went with a MOPAR accessory set of Kicker speakers for my upgrade. Any good 3.5" speaker will work unless it has a high cone, which will prevent you from being able to seat the defroster panel back in place unless you modify the speaker mounting bracket in the top of the dash.
These particular speakers have the connector slot on the body so they really are, plug and play.
If you go with a different set of speakers, you'll want to have a soldering iron and some solder available. You'll cut off the stock connectors on the harness, strip some insulation off the wiring and solder the connections.
When installing the speaker, you'll notice a small plastic alignment tab sticking up from the base of the mounting bracket on the dash. The speakers I chose have a small slot in the metal mounting bracket. I aligned the speaker mounting bracket up against this tab, then screwed it back into place.
If you purchase different speakers than I did, it's no big deal if your speaker mounting ring doesn't have the slot. Just dremel off the alignment tab and you are good to go.
Repeat the process on the other side and reinstall your defroster panel. Remember, leading edge goes in first, seat the panel in the slots at the base of the windshield and then gently push the back side down to seat the spring clips in their slots.
A suggestion from what I learned in doing this similar mod on my Chrysler. Don't replace the center speaker. It affects the sound and prevents you from getting true stereo separation and ability to balance the sound from side to side. If you have one there when you start, pull it out, tape up the connector so it doesn't rattle, push the harness down into the speaker cavity and call it good.
And that's how you do a front dash speaker upgrade to a 3rd Generation RAM. Easy, huh?
Old 05-12-2010, 11:27 PM
iRESQu iRESQu is offline
Rep:2217
I really appreciate this. I will be walking this road, helping Scott, in 3 weeks.
Rep:1625
That's a very helpful write-up, thanks MADDOG!!
Old 05-12-2010, 11:30 PM
Thanks, guys and it's my pleasure.
I'll be doing the door speakers (all 4) the amp and the navigation head unit this weekend so more pics to come!
Old 05-12-2010, 11:32 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Nice write-up! I never think about doing one even though my dash is off about every two weeks.
Kudos!
Old 05-12-2010, 11:35 PM
LOL, Daniel. I'm sure you'd have some awesome ones considering how many times you've gutted your interior for the next, great, audio mod!
Old 05-15-2010, 11:12 AM
Rep:2217
TODAY IS THE DAY!!!!!! Let us know how it goes! When's the group coming over? What time does the beer start aflowin'? The music ablarin'?!
Old 05-15-2010, 11:21 AM
I'm getting ready to go out and do the headlight HID's (once again) and will have that finished before the group gets here around 11 AM.
The beer will flow AFTER the work is done. And I hope there's music to hear when we are done.
