Old 01-29-2010, 12:53 AM
I push the skinny pedal
Rep:3277
Looks great Michael! Now the hard part will be to stay off the go pedal so you can hear the growl.
Kurtis
Old 01-29-2010, 12:55 AM
Yup...that's gonna be a problem!
Old 01-29-2010, 01:13 AM
300 Addict's Avatar
300 Addict 300 Addict is offline
Vehicle: Chrysler 300
Trim Level: Touring
Color: Satin Jade Metallic
Rep:317
300 Addict is a jewel in the rough300 Addict is a jewel in the rough300 Addict is a jewel in the rough300 Addict is a jewel in the rough
Nice choice Michael! Those Magnaflows looks awesome! Love the tips!
Gotta get a video of how they sound now
Old 01-29-2010, 01:26 AM
MightyBlueRam's Avatar
MightyBlueRam MightyBlueRam is offline
Vehicle: 2014 Ram 1500 EcoDiezl Laramie
Trim Level: Laramie 4x2
Color: Blue Streak Pearl Coat
Rep:432
MightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really nice
Those tips look great Maddog! I can't wait to hear how they sound.
Old 01-29-2010, 01:30 AM
Snowman's Avatar
Snowman Snowman is offline
Vehicle: 2010 Cummins 3500 Crew cab
Color: White/two tone
Rep:34
Snowman is on a distinguished road
Sweet exhaust you got there. Must sound nice.
Old 01-29-2010, 01:36 AM
Thanx, snowman. It does sound good...like a real truck should.
I'll get a vid of it soon and post it up.
Here's what my '99 5.2L sounded like with a similar muffler...but I'll tell ya right now, this truck doesn't exactly sound the same
Old 01-29-2010, 12:35 PM
killerbee's Avatar
killerbee killerbee is offline
Vehicle: 2004
Trim Level: SLT RumbleBee Editio
Color: Solar Yellow
Rep:369
killerbee is just really nicekillerbee is just really nicekillerbee is just really nicekillerbee is just really nice
Send a message via Yahoo to killerbee
Nice mod. Looks good.
Where there's one, there's sure to BEE more.
Old 01-29-2010, 12:50 PM
will's Avatar
will will is offline
Vehicle: 2010 dodge ram quad cab
Trim Level: slt/bighorn
Color: silver
Rep:43
will is on a distinguished road
Vey good pics
OLD TRUCK
NEW truck soon to be here
Old 01-29-2010, 01:29 PM
Rep:1625
The pics look great. The truck is really looking good.
Old 01-29-2010, 06:17 PM
OK...so here's the next set of mods.
I purchased a couple of items for the truck. First, a simple drop in K&N filter. I'll use this for now until I decide what intake to go with.
Next, I went to my favorite speed and tuning shop in Portland, Performance Race Engineering. They tuned my SRT8 last year with great results.
I dropped in the filter then the great guys at PRE strapped the Ram to the dyno.
We did a baseline dyno pull and all I gotta say is ugh...what a dog...LOL Here's how they strapped it down in the back.
I had made arrangements to upgrade the truck and they had the tools ready, a DiabloSport Predator U7137:
I wasn't looking to get a lot of HP but did want some more torque and better driveability. I also wanted to correct the speedo error for the larger wheels and tires. I got all of that for sure and one other bonus feature, better shifting with a bit of an increase in transmission line pressure.
Here's the dyno charts. I saw a HP and torque increases across the board, it comes on a bit sooner and my Air/Fuel ratio is now spot on.
I'm seeing more HP and torque at lower RPM's so that's a good thing!
Now, Air / Fuel Ratio. This was important to me as I know how lean a stock engine runs. For those of you not up on the term, it simply means how much fuel is being fed into the engine in relation (ratio) to how much air.
The 5.7L HEMI (and 6.1L for that matter) stock program runs at 14.1 A/F in static mode, i.e., when at idle or at steady state cruise. 14.1 A/F is a lean mixture, i.e., lower fuel to air ratio. Lean is good for mileage, not good for power. The stock program will add fuel to the mix as the engine demands but it does not always add enough to hit optimum A/F for power. And it waits a long time before it does it, keeping the engine lean at WOT for too long, robbing it of power and inducing knock retard.
The HEMI seems to like a 12.5 to 12.8 A/F.
Therefore, your HEMI is pretty close to reading knock at WOT and the computer will pull fuel and timing to avoid engine damage. The MOPAR stock program is pretty conservative and aggressive with respects to knock retard.
With the Predator 91 octane tune installed, A/F improves considerably and gets it into the "sweet spot" for the HEMI. What's cool about the Predator tool is that if the canned tunes don't get you there, there's an option to add (if it's still in a lean condition) or delete fuel (if it's too rich - haven't seen that happen much with a stock program on the HEMI) to hit the sweet spot.
In the chart below, the line that starts right at the 14.1 measurement is the stock program. It almost stays there the entire time and it's way too lean. It dropped down below 12 way up in the RPM range. That means it was running lean almost to redline and it was knocking, then it got very rich.
The line above that, starting at around 14.6 A/F, is the Predator tune measurement. It starts to drop almost immediately and hits the sweet spot right at where the engine is designed make max HP. I won't have to add any more fuel.
So, in perusing the dyno sheet carefully, the truck went from 240 lb ft @ 4800 rpm to 295 lb ft @ 3750 rpm (that's 55 lb ft improvement and it comes lower) and from 230 hp @ 4800 to 275 HP @ 3400 (that's 45 HP improvement and it comes lower in the rpm band).
Anyway, enough of the technical discourse, here's the chart.
All in all, I'm very happy with the results. Eventually, I'll go back to PRE and get a CMR tune for some fine tweaking and more power.
