Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Electrical
Place your Ad Here!
Old 01-28-2010, 10:15 PM
BeerMan BeerMan is offline
BeerMan is on a distinguished road
Default Remote Start Problem - Need Help
Hi Guys. I'm having a problem with my remote start on my 09 Laramie. when I hit the remote start button the truck starts and then shuts off after 3-4 seconds. It also displays "Remote start disabled - system failure". I've had it in to the dealer twice with no luck. Any similar stories or solutions?
Old 01-28-2010, 10:20 PM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
mine cuts out if the truck thinks there is something wrong with itself
Old 01-28-2010, 10:30 PM
MightyBlueRam's Avatar
MightyBlueRam MightyBlueRam is offline
Vehicle: 2014 Ram 1500 EcoDiezl Laramie
Trim Level: Laramie 4x2
Color: Blue Streak Pearl Coat
Rep:435
MightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really nice
Page 27 of the manual....
Remote Start Abort Message on Electronic Vehicle
Information Center (EVIC) — If Equipped)
The following messages will display in the EVIC if the
vehicle fails to remote start or exits remote start prematurely:
• Remote Start Aborted - Door Ajar
• Remote Start Aborted - Hood Ajar
• Remote Start Aborted - Fuel Low
• Remote Start Aborted - System Fault
You have any of those?
Old 01-28-2010, 10:32 PM
Yes, the last one you listed "System Fault"
Any ideas??
Old 01-28-2010, 10:37 PM
lancelanz's Avatar
lancelanz lancelanz is offline
Vehicle: 2009 Ram 1500 Crewcab 2wd
Trim Level: SLT/Big Horn
Color: Austin Tan Pearlcoat
Rep:65
lancelanz will become famous soon enough
Send a message via Yahoo to lancelanz
when mine did it it was the RRT for the washer fluid level sensor harness. it had something to do with the fluid leaking and running down the harness and messing up the outside temp sensor at least that is what the dealer told me. once they replaced the harness it has not happened again.
09 Ram 1500 Big Horn Crew Cab Hemi Spray in bedliner,Flowmaster Original 40,6000k HID lows/fogs
Old 01-28-2010, 10:38 PM
Rep:435
When you got that fault, did you press the gas or shifted into gear without the key in?
Old 01-28-2010, 10:42 PM
No. It does it and it is displayed on the dash when I open the door.
Old 01-28-2010, 10:43 PM
What is the "RRT"?
Old 01-29-2010, 04:29 PM
sowardcustoms's Avatar
sowardcustoms sowardcustoms is offline
Vehicle: 2013 Ram R/T
Trim Level: R/T
Color: Gray
Rep:145
sowardcustoms will become famous soon enoughsowardcustoms will become famous soon enough
Its actually a recall now its number J06 there is a RRT on 09 DS truck for a malfunctioning hood switch that could disable remote start RRT #09-084
Old 01-29-2010, 04:32 PM
Resident Technician
Rep:1915
That's not the same one. The RRT is for a problem with the washer fluid level sensor leaking and wicking fluid into the harness with the ambient temp sensor.
