tonneaucovered.com
Old 01-29-2010, 10:14 AM
08quadram's Avatar
08quadram 08quadram is offline
Vehicle: 08 Ram Quad 1500
Color: silver
Rep:22
08quadram is on a distinguished road
Unhappy Frozen windows
How many suffer from frozen windows in the winter. I would be 8 out of 10 times I want to use one of my windows, it is frozen shut. It gets quite annoying. It is worse than any other vehicle I've ever owned. What do you guys and gals use to keep your windows from freezing shut?
Mike
'08 1500 Ram, Quad 4x4 Bighorn, Silver, 20" wheels, 5.7 Hemi/MDS, 3.92 axles
"Meddle not in the affairs of dragons, for thou art crunchy and good with catsup" -Doc, IFSJA
Old 01-29-2010, 10:20 AM
SRTAndy's Avatar
SRTAndy SRTAndy is offline
Vehicle: 08 Charger
Trim Level: SRT
Rep:404
SRTAndy is just really niceSRTAndy is just really niceSRTAndy is just really niceSRTAndy is just really niceSRTAndy is just really nice
I grew up in Montana and our garage wasn't big enough for all of our vehicles so I always had to park in the driveway! Anyway, I bought a cab cover that basically just covered all my windows and that worked great. Just google "cab cover" and you will see what I mean.
When in doubt, read the Forum Rules
You can help support your favorite Dodge Ram site by becoming a Site_Supporter
"How To's" that will help you learn how to use the forum features can be found here!
Old 01-29-2010, 10:56 AM
uktitus uktitus is offline
Vehicle: 2009 dodge Ram 1500 4x4
Trim Level: Laramie crew cab
Color: Grey
Rep:41
uktitus is on a distinguished road
Default newspaper
newspaper, foam, towel, try that, anything that you can be trapped by the door, covers the window, and the door will close completely ,
Old 01-29-2010, 01:17 PM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
move to a more southern climate
sorry couldn't resist
Exco
Bill
Old 01-29-2010, 04:07 PM
I push the skinny pedal
Rep:3308
You can spray some silicone spray on the rubber and that stops it sticking. I have it pretty bad with my in-channel vent visors freezing to the window, my solution is to knock the window around the edges to crack the ice then it normally lets the window move with no issues.
Exco
Shut Up... I had to work outside this morning.
Kurtis
Old 01-29-2010, 05:32 PM
bones64's Avatar
bones64 bones64 is offline
Trim Level: slt/sport (bones)
Rep:659
Do what i do. If its just your windows freezing then have them down just a touch. Not so anything gets in just a bit. Works for me. I do them all the way up and then down a touch.
Old 01-30-2010, 09:26 AM
MightyBlueRam's Avatar
MightyBlueRam MightyBlueRam is offline
Vehicle: 2014 Ram 1500 EcoDiezl Laramie
Trim Level: Laramie 4x2
Color: Blue Streak Pearl Coat
Rep:435
MightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really nice
These are some good ideas that everyone is suggesting.
http://ramforumz.com/showthread.php?...light=silicone
Old 01-30-2010, 09:41 AM
vided vided is offline
Vehicle: 2010 ram quadcab
Trim Level: slt,big horn,bucket
Rep:22
vided is on a distinguished road
i went out this morning in lovely 2degree temps, my windshield was totally
frosted, ON THE INSIDE, this is the first time on any car i've had that happen.
anybody know why?
2010 quadcab ram hemi,
Old 01-30-2010, 10:12 AM
Rep:435
There must have been some moisture in the air inside of your truck. With the cold temperatures that moisture in the air inside your truck turned to frost. I've read that running the a/c on recirculate can cause that because they is no dry cold air from the outside coming in. I also read that running the a/c so that air comes from the outside prevents the frost buildup.
Old 01-30-2010, 10:33 AM
Zonestar's Avatar
Zonestar Zonestar is offline
Rep:235
Zonestar has a spectacular aura aboutZonestar has a spectacular aura aboutZonestar has a spectacular aura about
I would do my best not to go outside if it was 2 degrees.
