Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Heating & Cooling
tonneaucovered.com
Old 01-29-2010, 01:03 PM
dblwringer dblwringer is offline
Vehicle: 2006 Ram 1500 QC
dblwringer is on a distinguished road
Default HVAC Mode Door problem
I have a 2006 Ram 1500SLT Quad Cab.I started to have a problem when I switch my heat from defrost only setting to the floor only outlets the heat still blows out from the defrost.When I switch from defrost to vent the heat blows out the vents like it should.I switch back to floor setting and heat blows out from defrost again.With the truck off and the key in the on position,I go through all the settings one at a time and I hear a motor or something activating with each position.I turn on the blower in the floor position and the air still comes out the defrost.I looked up into the floor vent opening and when I change from defrost to floor setting I see the door starts to open about a quarter inch but then falls back down. Any thoughts? Thank You
Old 01-29-2010, 01:08 PM
Resident Technician
Rep:1911
Probably a broken mode door.
Old 01-29-2010, 04:13 PM
I push the skinny pedal
Rep:3308
Common issue with the 3rd gens. Replacing the motor and/or door will solve this.
Kurtis
