Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Electrical
Electrical 1st Gen Dodge Ram Electrical Problems and Questions.
Old 01-30-2010, 09:11 AM
Olddodger Olddodger is offline
Vehicle: 1984 3/4 ton
Trim Level: ?
Engine: 1981-1988 360ci (5.9L) LA V8 170hp
Olddodger is on a distinguished road
Default Vehicle polarization
Can welding on the chassis polorize the vehicle and make the charging system inoperable
Old 01-30-2010, 09:47 AM
Rep:1884
Shouldn't be a problem. There was a recall back around 2000 that required us to weld a bracket onto the front suspension and all we did was unhook the battery and everything was fine.
Old 01-30-2010, 10:32 PM
hipshot hipshot is offline
Vehicle: 2009 Dodge Ram Quadcab
hipshot is on a distinguished road
I've welded on a lot of vehicles (although none of the newer ones with all the computers) without problems. Just disconnect the battery at the ground terminal and be sure to place the welder's ground clamp as close to the work as possible. Make sure nothing flammable is leaking.
