Old 01-30-2010, 07:27 PM
riggzy riggzy is offline
Vehicle: 1999 Dodge Ram 1500 Sport 4x4
Trim Level: ?
Color: Yellow
riggzy is on a distinguished road
Default Tallest 16inch tires on stock 99 ram 1500
So its tax return time and im runnin on a spare and one tire with a broken belt(holdin air though for now) so i figure id buy some tires. I was just wondering what the tallest tires i can fit on my 99 dodge ram would be. I have no lift or leveling kit, my tires now are 265/75/16's. I want a taller more agressive look so i was thinking of going newhere from 285-315/75/16 if possible..I really dont want the tires to rub when turning tho.. My "kno it all buddy" says you can adjust your torsion bars so your tires wont rub. Any thought or input would be greatly appreciated. Thanks and hello to all i'm new to ramforumz!
Old 01-30-2010, 09:20 PM
I push the skinny pedal
Rep:3277
Welcome. You can fit 33s without touching your torsion bars, but you can jack up the torsion bars easy enough and fit 35s, but might rub due to width.
Kurtis
Old 01-31-2010, 05:58 AM
Trim Level: ?
Color: Yellow
And the 315/70/16 would be 33 right? Makin sure my calculations are correct.
Old 01-31-2010, 07:49 AM
Rep:1885
I've seen plenty with 285's and 305's on them without lift kits.
Old 01-31-2010, 02:04 PM
DaKid's Avatar
DaKid DaKid is offline
Vehicle: 2000 Ram
Color: Dark Garnet Red Pearl Coat
DaKid is on a distinguished road
I have 265/70/16 Terra Grapplers and they rub on the lower control arm if I crank the wheel all the way in one direction. Those are on the stock 16" steel wheels
Old 01-31-2010, 04:02 PM
foxcrazy90's Avatar
foxcrazy90 foxcrazy90 is offline
Vehicle: 2008 dodge ram 1500
Color: electric blue pearlcoat
Rep:584
foxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to all
yes,almost a 33.5 x 12.50
NEIL KELLEY
2008 ram 1500 bighorn 4x4
2 1/2 level lift--hella 500ff grill lights--17x9 centerline grizzly-305-70-17 nitto terra grapplers--front air valance removed--tinted windows--custom audio system clarion vz401 head unit--pioneer 4channel amp and class D mono amp--memphis mclass door speakers--clarion dash speakers--kicker subs
Old 01-31-2010, 05:47 PM
Trim Level: ?
Color: Yellow
Thanx for the input guys. The tires would be mounted on stock rims forgot to mention that. Thinkin of 305 70 16 kumho road ventures or hankook dynapros. Ne one had either of these tires?
Old 01-31-2010, 11:34 PM
Rep:3277
Here's a converter if you need it
http://www.dakota-truck.net/TIRECALC/tirecalc.html
Kurtis
Old 02-01-2010, 03:12 PM
ScatPak07's Avatar
Rep:970
I have 305s on mine they sit 33" tall. I have rubbing when I crank the wheel to the lock. It's only in parking lots . I also have a 2.5" lift, but its an '07 so may be different. Just wanted to put my $.02 in, try and help haha
