Old 01-30-2010, 11:40 PM
Fast Willy's Avatar
Fast Willy Fast Willy is offline
Vehicle: 2008 Dodge Ram QC
Color: Blue
Rep:31
Fast Willy is on a distinguished road
Send a message via AIM to Fast Willy
Default Dual alternator setup?
Does anyone know if they have a dual alternator setup for the 5.7 Hemi motor. Either Stock or after market? I will be installing a large system hopefully here soon and would like the setup to look as factory as possible.
Thanks, Bill
Old 01-30-2010, 11:55 PM
Sparky's Avatar
Sparky Sparky is offline
Vehicle: '06 Ram Quad Cab HEMI
Color: FLAME RED
Rep:23
Sparky is on a distinguished road
You also could look into getting your alternator rewound for a higher ampacity. Or see If you can just buy one already done. Also when putting in large systems a capacitor is a great investment, it saves on headaches later.
Old 01-31-2010, 10:38 PM
Fast Willy's Avatar
Color: Blue
Rep:31
Yes, I'm just really looking for the brackets to mount the 2 alternators and maybe some belt info. The alternators I'm going to be using are 2 custom 280 amp maybe for me by ihio generator. And I will be using a capacitor as well.
Old 01-31-2010, 10:50 PM
ramit04's Avatar
ramit04 ramit04 is offline
Vehicle: 2004 Dodge ram 1500
Rep:74
ramit04 will become famous soon enough
make sure your system is going to need that much ampage, just like sparky said a capacitor will save you alot of time and money
Old 02-01-2010, 07:45 AM
CHILLZ HEMI's Avatar
CHILLZ HEMI CHILLZ HEMI is offline
Vehicle: 2008 Dodge Ram 5.7L HEMI
Trim Level: Big Horn, Quad Cab
Rep:47
CHILLZ HEMI is on a distinguished road
Send a message via AIM to CHILLZ HEMI
Two alternators are really not as good as it sounds...Its more of a headache to try to make such a setup, than going out and buying a HC alternator and Capacitors that can handle the power from your stereo system...Not to mention the loss of engine power, etc. because of the extra load from the alternator and belt design....
Old 02-01-2010, 09:01 PM
Phrede Phrede is offline
Vehicle: 2008 MegaCab
Phrede is on a distinguished road
What are you doing with a constant requirement of 500+ amps of 12Vdc power? I would think trying to balance such a system on one battery would be a nightmare so I assume you would be using dual batteries. Have you considered an auxiliary generator (self powered) instead?
Old 02-02-2010, 12:07 AM
Fast Willy's Avatar
Color: Blue
Rep:31
I will not be just on one battery. I thinking of running 8 Fi BTL's in the bed and doing a blow threw.
Old 02-06-2010, 09:20 PM
That should shake things up.
Old 02-06-2010, 09:26 PM
Snowman's Avatar
Snowman Snowman is offline
Vehicle: 2010 Cummins 3500 Crew cab
Color: White/two tone
Rep:34
Snowman is on a distinguished road
WHAT?? I can't hear you over all that noise.
