Old 01-31-2010, 12:42 AM
nwtram nwtram is offline
Vehicle: 2003 Dodge Ram Quad Cab 4x4
nwtram is on a distinguished road
Default Tranny codes when cold
Newbie here...Don't know if anyone else is having the same fault with a 2003 Dodge 1500 Hemi (5 speed auto).
I live in an area with extreme cold in the winter and have been having intermittent tranny codes (since 2007) when temps are about -30 C (-22 F) and colder. The truck is plugged in and warmed up for up to 5 minutes before driving and on occasion I get various codes such as P0845, P0870, P0987, P0841. Sometimes they occur as single code, sometimes in various combinations. They all seem to be related to tranny fluid pressure sensor/switch circuits. After the code(s) occur there is a sluggish feel to the acceleration but when the engine is stopped and restarted a few minutes later, the performance returns to normal. Dealer says problem is due to a fault with the wiring harness. Anyone with ideas?
Appreciate any feedback. Thanks in advance.
Old 01-31-2010, 09:11 AM
Rep:1885
Unfortunately the only advice I can give you is to check the fluid level and drop the pan and see if perhaps the filter is clogged causing a low pressure issue. I'm having a problem with the wiring diagnosis since it only does it on an extremely cold start up. All the codes you mentioned are low pressure related. Have you had the trans serviced lately?
Old 01-31-2010, 09:40 AM
The tranny was serviced in mid 2007 by the dealer.
The dealer has, by a process of elimination, decided that the TCM (Control Module) is not at fault and I do agree with this since the fault also occurred with a replacement module installed. They came to the conclusion that the transmission wiring harness was the problem when they switched some wiring harness points around and generated new codes: P0765 Shift Solenoid D, P0750 Shift Solenoid A, P0720 Output Shaft Speed Sensor Circuit,
P0715 Tubing/Input Shaft Speed Sensor Circuit, P1794 Speeds Error: Speed sensor ground.
While driving with these harness wires switched around the transmission operated extremely poorly, hesitating, over-revving before clunking into the next gear, etc. and the problem went from only occurring in the cold to being chronic for the week the wires were switched. Now the wiring harness is back to the proper set up and the problem is only happening in the cold. The dealer has given up troubleshooting a tranny repair and says I need to replace the wiring harness. Their idea is that, during the cold, there is shrinkage in the wire(s) and/or electrical connectors.
Old 01-31-2010, 09:55 AM
Rep:1885
If it were throwing codes for high/low voltages or open/shorted circuits I would have a lot easier time buying into that theory although I can't entirely discount it either.
Old 01-31-2010, 03:23 PM
One of the problems I have with the dealer diags is that, when troubleshooting, they moved some wires in the harness and the problem went from being intermittent and cold related to being chronic with different codes. Also, should note that the fault only shows up in winter (never in summer) after starting and driving the vehicle in the morning after it has sat outside overnight. There is a slight hesitation in shifting from first to second and then a fault code registers as a MIL (Malfunction Indicator). If the codes do not show up after a cold morning start, then we are good for the rest of the day.
