Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Knowledge Base
Old 01-31-2010, 10:30 AM
Rep:1877
Post MDS - A Brief Overview
The Multiple Displacement System (MDS) provides cylinder deactivation during steady speed, low acceleration and shallow grade climbing conditions to increase fuel economy. Both four and eight cylinder configurations have even firing intervals providesmooth operation. Two cylinders on each bank are active when the engine is in four-cylinder mode – every other cylinder in the firing order. All of the cylinders that are deactivated have unique hydraulic valve lifters that collapse when deactivated to prevent the valves from opening. Engine oil pressure is used to activate and deactivate the valves. It is delivered through special oil passages drilled into the cylinder block. Solenoid valves control the flow. When activated, pressurized oil pushes a latching pin on each valve lifter, which then becomes a “lost motion” link. Its base follows the camshaft, but its top remains stationary, held in place against the pushrod by light spring pressure but unable to move because of the much higher force of the valve spring.
NOTE: It is critical to use the recommended oil viscosity in 5.7L engines that use MDS.
Deactivation occurs during the compression stroke of each cylinder, after air and fuel enter the cylinder. Ignition then occurs, but the combustion products remain trapped in the cylinder under high pressure, because the valves no longer open. No air enters or leaves. During subsequent piston strokes, this high-pressure gas is repeatedly compressed and expanded like an air spring, but fuel is not injected.
Old 01-31-2010, 10:58 AM
BlueJet BlueJet is offline
Vehicle: Blue
Rep:3934
Nice write up....thank you for this!
Old 01-31-2010, 11:33 AM
will's Avatar
will will is offline
Vehicle: 2010 dodge ram quad cab
Trim Level: slt/bighorn
Color: silver
Rep:43
will is on a distinguished road
Very nice Randy. It still amazes me how this all works.
OLD TRUCK
NEW truck soon to be here
Old 01-31-2010, 02:20 PM
I knew it was done threw the lifters but didn't know how . Thanks for the insight .
Old 01-31-2010, 02:36 PM
MADDOG MADDOG is offline
Rep:22
Great write up, Randy.
So do you know what years/model RAMs were equipped with MDS?
Like, I'm wondering if my 2007 5.7L MegaCab has it. I think not.
Old 01-31-2010, 02:49 PM
Rep:1877
2006 was the first model year for MDS in the Ram. The Mega Cab wasn't offered with MDS even though it's rated as a half ton truck.
Old 01-31-2010, 03:47 PM
MightyBlueRam's Avatar
MightyBlueRam MightyBlueRam is offline
Vehicle: 2014 Ram 1500 EcoDiezl Laramie
Trim Level: Laramie 4x2
Color: Blue Streak Pearl Coat
Rep:432
MightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really nice
Thanks for the info! Very interesting stuff and it amazes me how complicated engines can be.
Old 01-31-2010, 03:51 PM
Rep:1877
When you tear one down, it's really not as complicated as it seems. Some of the components are different but the only real parts additions are the solenoids. Even the VCT isn't terribly complicated.
Old 01-31-2010, 04:13 PM
Rep:432
Oh wow, I just noticed the new "ASE/CHRYSLER certified technitian" badge!!! Looks great.
Old 01-31-2010, 04:15 PM
Rep:1877
Just got that a couple of hours ago. Stacy made that one possible.
