Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Knowledge Base
Old 01-31-2010, 03:28 PM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
Rep for the write up. I'm always amazed at how a simple solution(not necessarily easy) can accomplish so much. Thanks to Stacy for putting up the badge as well. All of Randy's posts show his knowledge, the badge makes it easier to know when you are getting a reputable source.
Old 01-31-2010, 10:36 PM
Big Daddy's Avatar
Big Daddy Big Daddy is offline
Vehicle: 2009 Crew Cab / 3.92 rear end
Trim Level: SLT Big Horn
Color: Stone White
Rep:917
Big Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to behold
Good one Randy. Rep for the info.
Like the new badge too. Stacy comes through once again.
Big Daddy
Marching to Mamasita's beat for a real real long time...
____________________
Dennis
Old 01-31-2010, 10:40 PM
MADDOG MADDOG is offline
Rep:22
Woohoo! I don't have MDS!!!
Now that makes my day.
Old 01-31-2010, 10:53 PM
Rep:4072
Very nice write up Randy, thanks for the info and nice badge BTW!!!
Old 02-02-2010, 09:19 PM
Phrede Phrede is offline
Vehicle: 2008 MegaCab
Phrede is on a distinguished road
Originally Posted by Remerson228 View Post
2006 was the first model year for MDS in the Ram. The Mega Cab wasn't offered with MDS even though it's rated as a half ton truck.
No MDS on Mega Cabs just in '06 or '06-'09?
Old 05-27-2010, 04:03 PM
Raptor1000R's Avatar
Raptor1000R Raptor1000R is offline
Vehicle: 2010 Ram 1500 4x4 Sport Crew
Trim Level: Sport, buckets, RER
Color: bright white
Raptor1000R is on a distinguished road
I'm surprised they don't hold the valves open a bit (not enough to hit the piston) so that it doesn't rob power on both compression/decompression strokes. Ideas?
2010,15004x4,Hemi,Sport,White,Crew,CAI,Predator,Li ne-X,Truxedo Lo Pro,2"level kit,PE Powergate
Old 05-27-2010, 04:20 PM
RamTech RamTech is online now
Rep:1885
The idea behind this is that the same force that resists rotation of the crank on the up stroke will aid in rotation on the way down.
Old 05-27-2010, 04:35 PM
Color: bright white
Thanks Randy, that makes sense. I'm sure "they" did plenty of R&D by now to see what works best. Prob. a wash on loss of hp to rotate, since 4 of them are disabled.
Thanks!
Old 05-27-2010, 05:19 PM
Rep:2657
The 1500 MegaCab is really a 2500 with a "1" on the door instead of a "2". The HD trucks did not use MDS, thus the 1500 Mega did not either.
I read this somewhere recently about the MDS (multi displacement system) it sounds resonable
Heres how it works, when the valves for those particular cylinders are closed, the exhaust gas is still stuck in there from the previous ''burn'' (this is done on purpose).... as the ''non-working'' pistons move up they compress the exhaust gases, but since the valves are closed this creates something like an ''air spring''. When the exhaust gas is compressed during the piston’s upstroke, then push down on the piston during its downstroke. The compression and decompression of the trapped exhaust gasses have an equalizing effect – overall, there is virtually no extra load on the engine.
Old 05-27-2010, 11:05 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
.....Deactivation occurs during the compression stroke of each cylinder, after air and fuel enter the cylinder. Ignition then occurs, but the combustion products remain trapped in the cylinder under high pressure, because the valves no longer open. No air enters or leaves. During subsequent piston strokes, this high-pressure gas is repeatedly compressed and expanded like an air spring, but fuel is not injected......
Does this mean there is a solenoid for each of the four cylinders so they can be deactivated 1 at a time....but in the same 2 rotation time line ?
brad
Interested in one of my mods?
