Broken Exh manifold bolts - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 > Exhaust
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 01-31-2010, 12:37 PM
Almond 04's Avatar
Almond 04 Almond 04 is offline
Vehicle: 2010 Ram 1500
Trim Level: Big Horn SLT
Color: Austin Tan Pearl
Rep:30
Almond 04 is on a distinguished road
Default Broken Exh manifold bolts
Hello everyone, I am new here and looking for a little help. I currently have a 04 Ram 2500 hemi with 85K.
Last summer I heard a rattling sound from the RH side of the truck. I found the exhaust manifold heat shield loose. Upon further investagation I found the nut end of the stud had broken off making the shield loose causing it to rattle. It was not rotted the fixed nut on the stud just broke off. Looked like it was cut. So I replaced it with a new stud and all was good. Didnt think too much about it.
Fast foward to last week I can hear an exhaust leak on the LH side. After looking it over I find the heat shield loose toward the back of the motor. Sure enough the 2 rear most exhaust studs the heads are broke off flush with the manifold casting causing an exhaust leak. Looked at the other side and another is broken as well.
It dosent seem normal to me . I know there is alot of expansion and contraction wth the exhaust manifold as it heats up and cools. I was hoping there was a recall for this but I couldnt find anything.
Has anyone else ever seen or heard of this happening. The parts were only 45 bucks and I am going to attempt it in a little while. Looks like a simple project hopefully I dont have to remove the motor mount, maybey the starter? Who knows. I sprayed the 2 bolts at the flange where the head pipe bolts go. They look pretty rusty though.
Cabin A/F mod / Mopar CAI / 390hp hood spears / Extang Trifecta / Custom Badges / Interior-Exterior LED's / Painted eng cover
Old 01-31-2010, 12:46 PM
I had the same problem on a Ford small block in a 1/2T truck some years ago...they just snapped!
Old 01-31-2010, 12:55 PM
Resident Technician
Rep:1915
I've not seen this with the Hemi engines but the 4.7's are prone to it. Might want to use some antiseize on all the exhaust components that you remove.
Old 01-31-2010, 04:53 PM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
Make sure you use Grade 8 fasteners on those.
Old 01-31-2010, 06:35 PM
Almond 04's Avatar
Rep:30
Hey everyone just got done with the broken manifold bolts. Took about 3 hours. It was better than expected. I started by removing the head pipe bolts while it was hot, they were quite corroded but came out with ease. Then disconect the batt and removed the old heat shield. That exposed the 4 or 5 10mm bolts in the middle. Loosened and removed all fastners and worked the manifold out. I used a pair of vice grips to remove the 2 broken studs, luckily they came out no problem.
Cleaned manifold with a wire brush, cleaned gasket surface reinstalled with new gasket, hardware and heat shield. Tightened all bolts in a criss cross pattern. Used 2 new bolts washers and nuts for the flange and worked perfect. No exhaust leak no more broken bolts.
Now I just have to deal with one broken on the other side.
Old 01-31-2010, 09:50 PM
Good news . Glad it didn't put up to much of a fight .
