Old 01-31-2010, 07:02 PM
mkarns mkarns is offline
Vehicle: 1997 Dodge Ram Ext. Cab 4x4
Color: Green/Silver
mkarns is on a distinguished road
Unhappy Ram Dead......No Juice.....Help!
I have a 1997 Ram 1500 4x4.
It has 150,000 miles on it and runs great.
Today I went out to start it and it turned over twice and then it was like a fuse shot.
No electricity anywhere......no lights......no radio......no nothing.
I checked the fuses and battery, all are ok.
Just ran it yesterday fine.....alternator was charging like it should.
Not sure what to check next.....please help....
I'm desperate.
Thanks,
M. Karns
Old 01-31-2010, 07:05 PM
Rep:1845
Pull off both battery terminals and clean the posts and inside the terminals. If you have a voltmeter you should check power to the PDC and the brounds coming back to the battery.
Old 01-31-2010, 08:18 PM
Color: Green/Silver
It has a new battery, posts are clean.
What's the PDC?
Thanks......
Old 01-31-2010, 09:26 PM
Just because it's a new battery doesn't mean it couldn't fail . Put a voltmeter across it anyway and check . Check your ground on the engine block also . You should have a small red cable coming off the positive battery terminal . Make sure that is secure , and clean .
Old 02-06-2010, 02:38 PM
Color: Green/Silver
Default Update
I left the truck sit all week and went out today to check the terminals of the battery.
Guess what, the interior light comes on and the buzzer for the ignition switch works.......
Has the battery had a week to charge alittle?
I'll try to start it later on, keep ya posted.......
Old 02-06-2010, 02:41 PM
Rep:1845
Batteries don't charge themselves. You still need to check for voltage drops.
Old 02-06-2010, 02:54 PM
Rep:2616
if the battery proves to be the problem, get it tested, new batteries can be duds too,
if the battery tests good, you may want to charge it with trickle charger
Old 02-06-2010, 04:41 PM
Color: Green/Silver
OK, went out and tried cranking the engine.
As soon as I turned the key to start lost all power......
When I put the key on the accessory mode, I have radio, buzzer, interior lights, etc.
But everytime I tried to start it I lost all power while the key was in the engine cranking mode.
Put a solar trickle charger on it plugged into the cigarette lighter.......(do they work?)
Thanks for all the help...
Oh, I don't have a voltmeter........
Old 02-06-2010, 11:20 PM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
Even if the battery shows 12V, it may not have the amperage to start. Make sure the battery carries a load. Sounds like you may have a problem in the ignition switch, as everything works in ACC, but not when you try to start. Anyone else?
Old 02-06-2010, 11:35 PM
Rep:2616
possibly a starter solenoid
just another thing to check
