Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Interior and Exterior Lighting
Old 02-01-2010, 02:04 AM
kroll's Avatar
kroll kroll is offline
Vehicle: 04 Ram 1500 crew cab 5.7
Color: bule
kroll is on a distinguished road
Default Blinkers?
so here is a brain buster for you. after trying to get my HIDs to work i just gave up on it. and the other day my blinkers started acting up. i will push the turn signal shaft down and the right blinker will come on. and when i push it up nothing happens. but the weird thing is that i will flash my high beams a few time and that will fix it for a while. i checked the wires and didnt see any damage. could i of burned up the wires or computer by messing with the HIDS? or has anyone ever had this problem? thanks for your time
Old 02-01-2010, 03:04 AM
kroll's Avatar
Color: bule
the warranty is long gone....
Old 02-01-2010, 03:01 PM
Resident Technician
Rep:1915
I'm going to go out on a different limb and say the multifinction switch because it's a multiplexed setup and they're known to fail after a while. It's probably got a resistor going bad inside.
Old 02-01-2010, 07:50 PM
kroll's Avatar
Color: bule
is that something I have to go to the dealer for? or can it easily be done?
Old 02-01-2010, 08:04 PM
Resident Technician
Rep:1915
You'd need to get the part from the dealer but installation is pretty easy.
Old 02-01-2010, 08:45 PM
ScatPak07's Avatar
Rep:970
Try and get a relay harness. Power the HIDs straight from the battery. This might help
Old 02-02-2010, 02:33 AM
kroll's Avatar
Color: bule
i did have relay harness and when i turned on the lights both of them just blinked.
Old 02-02-2010, 02:37 AM
kroll's Avatar
Color: bule
thanks for the responses.
Old 03-02-2010, 11:30 PM
pwrmd pwrmd is offline
Gender: Not Specified
pwrmd is on a distinguished road
My truck has the exact same problem. Did you get it repaired?
Old 03-02-2010, 11:40 PM
Have you had any luck getting the HID problem straightened out ?
