Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 5.7L (345 cu in) HEMI V8 Specific Topics
Old 02-01-2010, 02:49 AM
RamHemi55's Avatar
RamHemi55 RamHemi55 is offline
Vehicle: 2009 Dodge Ram Sport 1500 Hemi
Color: Mineral Gray
Rep:14
RamHemi55 is on a distinguished road
Default 09 sport burning oil already???
Hey everyone, got an 09 hemi sport quad cab and the last couple times i got an oil change its been half a quart to a full quart low on oil. Its got 24k miles on it. anyone else having this problem? i went to the shop and looked under it and no oil leaks anywhere. clean as a whistle. Im taking it in tomorrow to the dealer to have it looked over and have a compression test done.
Old 02-01-2010, 02:57 AM
CHADDER03's Avatar
CHADDER03 CHADDER03 is offline
Vehicle: 2009 Ram Quad Cab
Rep:29
CHADDER03 is on a distinguished road
its a hemi thing... on my 09 it was down a litre at my first oil change. my 03 was the same every oil change it was down at least a litre. theres about 10 or so hemi's that have all there service done at the shop i goto and they are all the same. i dont know what it is but they seem to burn it up especially if you drive it like you own it
Old 02-01-2010, 03:03 AM
98sst's Avatar
98sst 98sst is offline
Vehicle: 1998 Dodge ram 1500
Trim Level: SS/T
Rep:883
I believe this is somewhat normal to be honest. However a quart is a lot of oil. I read that oil consumption with no signs of leaking is normal because it will lubricate piston rings and then burn up in the combustion chamber.
Old 02-01-2010, 05:30 AM
Resident Technician
Rep:1915
Are you making sure the level is to the top of the fill line on the stick after each oil change and then checking it right before the next service?
Old 02-01-2010, 03:44 PM
MiRamDriver's Avatar
MiRamDriver MiRamDriver is offline
Vehicle: 2014 Dodge Ram CC 4x4
Rep:14
MiRamDriver is on a distinguished road
Sounds a bit excessive to me.
Old 02-01-2010, 04:18 PM
LS Eater's Avatar
LS Eater LS Eater is offline
Vehicle: 2011 Ram Crew Cab Cummins
Color: Pearl White
Rep:12
LS Eater is on a distinguished road
You need a catch can. Its the little tube that goes into you air intake. it allows oil to recurculate into the motor and it is horrible. Run a can of SeaFoam throught the break booster and you will have a lot more power... get a catch can, i think diablo sport has one...
Old 02-01-2010, 10:34 PM
MotorCityRam's Avatar
MotorCityRam MotorCityRam is offline
Vehicle: 2010 Ram QC 4x2
Color: Inferno Red
Rep:23
MotorCityRam is on a distinguished road
Anyone that played w/ 5.0L Mustangs in the late 80's is used to this. Lighter ring set yields a little more oil consumption and gives a 120k motor that still shows crosshatch on the cylinder bore and can be re-ringed and fresh bearings and go for another 120K. Just keep a regular check on it. Little extra regular maintenance makes for a LONG life.
Sean M
2010 Quad Cap Sport 4x2 / Inferno Red / HEMI / 3.92s / leather / Truxedo Truxsport tonneau
Old 11-22-2011, 10:56 AM
pmilazzo001's Avatar
pmilazzo001 pmilazzo001 is offline
Vehicle: 09 Ram 1500 SLT
pmilazzo001 is on a distinguished road
Default what was the result?
I recently bought an 09 ram slt with the hemi and i just checked my oil this morning. its to the add mark on the dipstick. and the oil smells like gas. im almost to the 24k mi mark. what was the result when you brought in?
Old 11-22-2011, 11:06 AM
RamHemi55's Avatar
Color: Mineral Gray
Rep:14
Well the dealer said 1 qt of oil per 4k miles is within spec. I think its a bit much but what can you do.
Old 11-22-2011, 11:56 AM
no kidding its kind of rediculous at 24k
