Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 5.7L (345 cu in) HEMI V8 Specific Topics
Old 11-22-2011, 01:30 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
It's really not that abnormal. I'd say half a qt in 5k miles is typical. 1 qt in 5k miles is even normal. My 4.7L will burn half to one qt in the about 7k miles in between oil changes. Perfectly normal in my opinion. All engines have some oil consumption. If it starts to get to like 1 qt every 3k miles, then its' getting very excessive. My 4.7L has over 50k miles.
Sean
Old 11-22-2011, 04:24 PM
Otterdriver's Avatar
Otterdriver Otterdriver is offline
Vehicle: 2009 SLT MegaCab
Rep:165
Originally Posted by MotorCityRam View Post
Anyone that played w/ 5.0L Mustangs in the late 80's is used to this. Lighter ring set yields a little more oil consumption and gives a 120k motor that still shows crosshatch on the cylinder bore and can be re-ringed and fresh bearings and go for another 120K. Just keep a regular check on it. Little extra regular maintenance makes for a LONG life.
Had a brand new 89' 5.0L sedan with the 5 speed standard back in the day, kicked alot of ass with that car! And yes, I had to add oil periodically, no biggy, no smoke out the exhaust ever, and yes my Hemi is using about a litre every 10,000 km oil change interval too, I'm not too alarmed.
http://i1132.photobucket.com/albums/...62f9145c5d.jpg
STEALTH DELETES/ BUSHWACKER FLARES/ AMERICAN RACING RIMS/ MINI MAX 75 HP TOWING TUNE/ OD TUNE
Old 11-22-2011, 04:26 PM
snrusnak's Avatar
Rep:1388
Also I saw an earlier post about a catch can recirculating the oil to the engine, this is not correct, it does not recirculate the oil.
Sean
Old 11-23-2011, 11:30 PM
HEMILANCER's Avatar
Vehicle: 09 Dodge Ram
Color: deep water blue
Rep:85
loose tolerances help the engine last longer. if they build engines too tight they wear out faster. all cars are like that now. my mom had a late 90's caddy that was the worst. 2 quarts every 5k, they just designed it to hold 8 quarts to compensate.
Too many mods to fit here!
Old 11-24-2011, 09:42 AM
v8440 v8440 is offline
Vehicle: 2009 Dodge Ram
Rep:15
v8440 is on a distinguished road
Originally Posted by pmilazzo001 View Post
and the oil smells like gas.
Reckon you might ought to get that checked out? Oil isn't supposed to smell like gas.
'98 12v dually, 450 hp, 920 ft/lbs, ran 14.67 at 98 granny shifting the 5 spd, 278k
Old 11-27-2011, 08:37 AM
rumnuts's Avatar
rumnuts rumnuts is offline
Vehicle: 09 Dodge Ram 1500 QuadCab 4x4
Color: silver
Rep:17
rumnuts is on a distinguished road
i have posted this in other threads but i took my 09 in to the dealer for white smoke. they said 1q per 1500 is in spec.i used 2q in the last 5000mi oil change.ill keep an eye on it for this trip.it does seem a bit much.
LOUD PIPES SAVES LIVES!!!!!!!
Old 11-27-2011, 10:05 AM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PXR Black
Rep:2477
I thought the same when I first read that post however what I think they meant to say was that without a catch can the oil gets fed back into the intake and burned. The catch can will do just that, it will catch that oil and prevent it from entering the intake. So with the catch can you can see just how much oil would have been lost, hence why you would see a lower reading on the dip stick.
sales@revelperformance.com
