Passenger Seat Nosie - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
Old 02-17-2011, 11:49 AM
Rocket Rocket is offline
Color: Mineral Gray
Rocket is on a distinguished road
The passenger side is manual. The drivers side makes a slight squeak but nothing bad. A little grease would fix the drivers. The passenger has been greased to the point that it dripped off the rails and its still a problem
Old 02-22-2011, 03:17 AM
JPRO89 JPRO89 is offline
JPRO89 is on a distinguished road
Hey my truck has been in the shop for this issue several times now and they jsut keep lubing the seat rail its not working and I am getting really sick of all the little issues with this truck. I really dissappointed so far with this truck it was my first new vehicule, and my first dodge and has turned me away from buying another one. My drivers seat did this about a month after owning the truck and they replaced the reat base and rails it seemed to fix it I think I will suggest this next time it goes it which will be soon because of a couple other issues which i have been having for awhile with no fix
Old 02-23-2011, 08:11 PM
cudase's Avatar
cudase cudase is offline
Vehicle: 2011 Dodge Ram
Trim Level: Sport Crew Cab
Color: Mineral Gray Metallic
Rep:53
cudase will become famous soon enough
If it is a power seat making the noise, no amount of grease will fix it. The problem is with a faulty ball screw stop inside the track.
Old 02-23-2011, 08:17 PM
Dodgeramhemi09's Avatar
Dodgeramhemi09 Dodgeramhemi09 is offline
Vehicle: 2009 Dodge Ram 1500 CrewCab
Trim Level: SLT BIG HORN
Color: Deepwater Blue Pearl
Rep:51
Dodgeramhemi09 will become famous soon enough
This may sound like blasphemy but there have been many times I wish I would have kept my '97 1500....I have NEVER had a problem with that truck. It was solid as a rock with no squeaks, moans, groans, leaks. Trust me, I love my '09 but it just doesnt seem to be made as well as the '97 was...
Old 02-25-2012, 01:33 PM
tdfrye's Avatar
tdfrye tdfrye is offline
Vehicle: 2014 dodge ram limited
Trim Level: Limited
tdfrye is on a distinguished road
Default creaky seat fix
CREAKY SEAT FIX- Just an fyi, brought my 2009 Ram to the dealer for my passenger seat creaking noise when I have passenger. The dealer tried greasing up the tracks. That didnt fix it so i looked at it myself. Here's what to do, it worked for me so far. Reach under the rear of the seat and unclip the back flap (should have two plastic clips attached 2 fabric stretch bands),once unclipped do the same for the foam seat bottom, once thats unclipped lift it up and you will see a pipe, push grease in the seam of the inside flanges it runs through i believe that should fix it good luck!! (p.s. it looks like the flange is pressed with pipe sticking through it )
[IMG]http://***************/forum/images/kirsch/misc/progress.gif[/IMG]
Old 02-27-2012, 09:59 AM
LUBINATOR's Avatar
LUBINATOR LUBINATOR is offline
Vehicle: 2009 Ram 1500 SLT Quad Cab
Color: Inferno Red
Rep:12
LUBINATOR is on a distinguished road
Default My Seat Fixed,
I did have the same clunk sound when only making a right turn, either forward or reverse.
Grease did not help this, grease may help a squeak but not the clunk.
My wonderful wife road in the back and lay down behind the drivers seat and found it was the bottom base making the noise. It was replaced 3 months ago and I haven't heard it since.
RAM 1500 SLT QC 2009 INFERNO RED, ARE Lift Lid ,Spray on Bed Liner, K&N Drop In, Pioneer DEH P8400UB, Alpine Amp, Mopar Kicker sets in all doors and dash, 2 Polk 10" Subs, Polk AMP, SteelCraft Nerf Bars, Mopar Fog Lights, CalTrend Seat Covers, WeatherTech Front Mats, Putco SS Fender Liners, SuperBumper SS Hitch Step/Impact Absorber, Onki Aegis SS Center Guard, PIAA 2100 driving lights
Old 03-03-2012, 07:52 PM
Ironsides Ironsides is offline
Vehicle: 2009 Dodge Ram 1500 CC 4X4
Trim Level: SLT Big Horn
Rep:44
Ironsides is on a distinguished road
I had a passenger seat noise. The dealer greased it up, and it's been fine ever since. Now my drivers seat is making noise, more of a popping, and grease hasn't helped.
Old 03-18-2012, 08:55 AM
crusher's Avatar
crusher crusher is offline
Vehicle: 2014 ram sport crewcab rambox
Rep:392
crusher is just really nicecrusher is just really nicecrusher is just really nicecrusher is just really nice
Originally Posted by smarthead2006 View Post
Hey All,
Does anyone know if there is a Service item on the passenger front seat? When I have someone sitting there and i make a Left turn i can hear the sit make a noise. It sounds like it coming from the "rails" on the Seat .... Thought i would see if anyone is having that issue too!
Thanks
Nick
mine did it to, went to the dealer, they grease it, never had problem with it since,.. and its been about 2 years
2014 ram sport crew cab with ram box,side steps,sport hood,remote starter,8 speed &3.92 gear lsd,4 corner air susp,knn intake,mufflex 18, BT catchcan,bakflip F1 cover, powerstop brake kit.
Old 03-18-2012, 11:17 AM
Rep:44
My drivers seat was making noise, and it was getting worse as time went on, so I looked at it yesterday. It sounded like a faint metal tension popping sound. Long story short, I put rubber washers between the seat frame and where it mounts to the truck body, as well as between the seat frame and the bolts that secure the frame to the truck. $6 in rubber washers, and the seat is dead quiet.
