Old 02-02-2010, 07:16 AM
Luis Luis is offline
Vehicle: 1995 Dodge Ram Laramie SLT
Luis is on a distinguished road
Default Question about type of engine
Hi, I am still discovering my Dodge Ram. Its a 1500 Laramie SLT , year 1995, and come from Canada. First license plate register in my country was 1997.
Under the hood I still dont know what engine I have. The valve cover on the left side has a tag saying 418. Is this some id of this engine ?
I have lots of more questions but first I have to made a complete recon next weekend and then , I'll let you know more.
Thanks
Old 02-02-2010, 07:45 AM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
if you look on the fan shroud you should see a white sticker that shows the path to properly run your belts.
somewhere on this sticker it should tell you what size engine you have, be it 5.0L or something similar... it's also not uncommon to show the proper gap for your spark plugs.
someone correct me if I'm giving bad info here. This is frequently how I'd ID engine size in older vehicles in the past
Exco
Bill
Old 02-02-2010, 08:15 AM
Rep:1885
It will be a 3.9, 5.2 or 5.9.
Old 02-02-2010, 08:39 AM
MightyBlueRam's Avatar
MightyBlueRam MightyBlueRam is offline
Vehicle: 2014 Ram 1500 EcoDiezl Laramie
Trim Level: Laramie 4x2
Color: Blue Streak Pearl Coat
Rep:432
MightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really nice
This might help you some.
http://dodgeram.org/tech/specs/VIN_decode.htm
Old 02-03-2010, 10:44 PM
Travis Travis is offline
Vehicle: 2014 Ram 2500
Trim Level: Outdoorsman
Travis is on a distinguished road
on the 95 you can check inside the glove compartment and that should provide some info for you.
