Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > V10 Specific Topics
Old 02-02-2010, 12:53 PM
badazram's Avatar
badazram badazram is offline
Vehicle: 1995 Ram 2500
Trim Level: Laramie Slt
Color: Green
Rep:72
badazram will become famous soon enough
Default Ok dudes... and dudettes
I have a 95 2500 V10... I just noticed this the past couple days.... When i make a turn the steering fells like it is intermittent... when i let the wheel go to return back to normal straight, it doesn't go back smoothly. kind of a stop,start kind of feeling. The 4wd works as i have used it a couple times. Could the weird steering feel be because of a hub not disengaging?
On a second note, the truck has a horrible shimmy from 50 to 75....the normal driving range. i just had the truck aligned and new tires put on it, all balanced and everything. Could this also be from a hub not disengaging?
im used to the hubs you have to get out and kick in.. i have an old 68 Chevy with manual steering and when i use 4wd in it the steering does the same kind of thing....
Let me kno what you guys and gals think....thanks in advance..Kevin
Common sense is genius dressed in its working clothes
Old 02-02-2010, 01:15 PM
HemiGTX's Avatar
HemiGTX HemiGTX is offline
Vehicle: 2004 Dodge Ram GTX
Color: Hemi Orange
Rep:33
HemiGTX is on a distinguished road
Have you changed your wheel bearings lately? If not, maybe that would be something to look into. Sounds quite similar to the same problem I was having. Good luck.
A way to check is lift the front of the truck and spin the wheels. If you hear a humming noise, then its probably time for some new ones.
2004 Hemi Orange Ram GTX #062
Old 02-02-2010, 02:04 PM
hauser775's Avatar
hauser775 hauser775 is offline
Vehicle: 2001 Dodge Ram 1500
Trim Level: SLT Laramie
Rep:67
hauser775 will become famous soon enough
Check your power steering fluid level. Also check to see if you have any punctures in any power steering lines. Low fluid can make power steering do goofy things.
Old 02-02-2010, 07:18 PM
badazram's Avatar
Color: Green
Rep:72
i checked the power steering fluid today and it turned out to be fine....i'll have to check out the wheel bearings tomorrow...thanks for the help so far...
Old 02-02-2010, 07:23 PM
Resident Technician
Rep:1909
Vibrations at those speeds are often caused by excessive radial runout. A normal dynamic balancing won't pick this up whereas a road force balance will.
Old 02-04-2010, 06:44 PM
badazram's Avatar
Color: Green
Rep:72
so i think i figured it out the steering thing was coming from the ABS sensors i think. sprayed them off with a hose seemed to smooth out the steering....pretty dumb problem
