Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 02-02-2010, 05:30 PM
kstroud kstroud is offline
kstroud is on a distinguished road
Default Trouble code p500
I have a 2005 ram 3500 w/5.9 diesel motor. The speedo is inop and the ABS and brake light are on. This was an intermittent problem but has now become permanent. I have a trouble code p500 speed sensor A, just wondering which sensor this is refering to?
Old 02-02-2010, 05:54 PM
Rep:1885
Is the P0500 the only code? You need to have the ABS module as well as the ECM scanned if you haven't already.
Old 02-02-2010, 07:02 PM
yes, P0500 is the only code. changed both sensors (transmission and rear end) cleared code and it comes right back. What will scanning the ABS module and ECM do?
Old 02-02-2010, 07:17 PM
Rep:1885
There might be additional codes stored. With a P0500 the wiring, ABS module or ECM is going to be at fault, not the sensors. One of the modules is seeing a speed signal but the other is not.
Old 02-02-2010, 07:20 PM
Thanks for the info
Old 01-09-2012, 02:14 AM
mannstripes mannstripes is offline
Vehicle: 1997 Dodge Ram 1500
Engine: 1995-1997 318ci (5.2L) Natural Gas V8 200hp 430lb/ft
mannstripes is on a distinguished road
Default 1997 trouble code P0500 AND P0138
My 1997 1500 w/manual tranny is hard to start, won't hold idle and stalls. Check engine light comes on. I pulled up trouble codes with a OBDII scanner, which shows P0500 and P0138. Any help would be greatly appreciated. Thanks.
Old 01-10-2012, 12:54 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
The 2 codes have nothing to do with each other.
P0500 - Speed sensor - Likely a wiring issue, but sensors have been known to fail
P0138 - O2 sensor at the rear of the catalytic convertor is likely bad. This would explain some of the running issue you explained. Don't buy the cheapest sensor out there. This is one time the OEM part is a good idea.
brad
Interested in one of my mods?
Old 01-12-2012, 12:59 PM
nibroc's Avatar
nibroc nibroc is offline
Vehicle: 89 dodge van, 92 dodge van
Trim Level: laramie
Color: light khaki metallic
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
nibroc is on a distinguished road
kstroud---yer problem is the sensor on the top of yer rear end--'bout $15
