Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Towing
Towing 3rd Gen Dodge Ram Towing Questions
Old 02-03-2010, 09:21 PM
Big Daddy's Avatar
Big Daddy Big Daddy is offline
Vehicle: 2009 Crew Cab / 3.92 rear end
Trim Level: SLT Big Horn
Color: Stone White
Rep:917
Big Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to behold
You've got some good info here. Pay heed to the safety tips. Another place you might want to check out is http://www.rv.net/. Just like the Z is the place to be and find out specifics for all things Ram, RV.Net is a great place to get info on all forms of RVing. They have a different forum for every type of RV including travel trailers and tow vehicle set ups. I've been a member there since 2002 and highly recommend you check it out.
Big Daddy
Marching to Mamasita's beat for a real real long time...
____________________
Dennis
Old 02-03-2010, 11:26 PM
car421 car421 is offline
Vehicle: 2006 Dodge Ram
Trim Level: Sport QC
Rep:16
car421 is on a distinguished road
Thanks, will do.
Old 02-04-2010, 10:30 AM
nhegel's Avatar
nhegel nhegel is offline
Vehicle: 2007 Dodge Ram 1500 Mega Cab
Color: Electric Blue Pearl Coat
Rep:31
nhegel is on a distinguished road
Originally Posted by americon View Post
I have a 2009 Dodge Ram 1500 with the 5.7L Hemi. I'm looking at buying a 29ft pull behind trailer that weighs 6200lbs dry and 8100 GVWR and my truck is good for 8350. I only plan on packing 1000lbs of camping gear in the trailer. I will also have a 600lbs quad in the box of the truck, and the truck/trailer will be equipt with break controller and stablizer hitch. I plan on driving in the mountains from time to time.
Will my truck be able to handle the load? If not what kind of weight should I look at as far as a trailers dry weight?
oh and my payload rating for the truck is 1150lbs and the trailers hitch weight is 912lbs.
Thanks
It sure will, as long as you dont mind buying fuel every 200 miles and going 40-45 up the hills. That is how my 5.7 pulls a 28' trailer
Old 02-04-2010, 12:13 PM
bamataco bamataco is offline
bamataco is on a distinguished road
You have been given lots of good advice. The only thing that I can think of to add is that you should consider wind resistance when buying. This can have a very adverse effect on your towing. More aerodynamic trailers will give you a little more gas mileage. And be easier to handle in windy conditions.
Old 02-05-2010, 11:26 AM
TJB10's Avatar
TJB10 TJB10 is offline
Vehicle: 2010 Ram 1500 SLT Crew Cab 4X4
Trim Level: SLT Sport Crew Cab
Color: Inferno Red Crystal Pearl Coat
Rep:20
TJB10 is on a distinguished road
When mounting your brake controller, locate it in a spot that you can get to it quickly, to activate the manual trailer brakes when needed in an emergency. Also I believe the larger tires will de-rate your maximum pulling capacity. I found that out last week when we purchased our new truck and looked at towing capacities of Rams with 17" tires vs. 20" tires. Go to www.dodge.com and click on towing. Good luck.
Old 02-05-2010, 07:50 PM
americon americon is offline
americon is on a distinguished road
thanks for the advice!
Old 12-24-2010, 01:59 AM
catheavyhaul catheavyhaul is offline
Vehicle: 2007 Dodge Ram 1500 Bighorn
Trim Level: slt bighorn
Color: silver
catheavyhaul is on a distinguished road
I have a 07 ram 1500 quad cab with a 5.7 ltr hemi and 20's w/tow package and pull a 29ft pull behind camper that weighs 5600 lbs dry wt, have a load leveling hitch w/sway control bar. going to add helper springs in the spring and maybe a rearend swaybar before i go camping again.
and may also upgrade my tires to cooper zenon 275/60r20XL's with a 2950lb rating. they whould have to be better than the crappy goodyear wrangler hp's it has now.
Old 08-10-2011, 07:34 PM
08 BigHorn's Avatar
08 BigHorn 08 BigHorn is offline
Vehicle: 2008 Dodge Ram
Color: red
Rep:23
08 BigHorn is on a distinguished road
Anti-Sway and load equalizer hitches are necessary. A brake controller is necessary. Make sure your tire load rating is sufficient to meet your GVWR (Gross Vehicle Weight Rating).
Look at your manual for your GVWR which is your truck and trailer in combination. That means the weight of the truck and trailer with your passengers, clothes, fuel, water, etc...that you will be packing with you. Don't fixate on towing capacity, be aware of your GVWR so as to avoid damage to the hitch and the truck.
To save some towing weight, unless you are going to a location with no water, don't fill up your fresh water tank until you get to your destination. And also drain it and your black water/grey water tanks before you hit the road home.
Very good advice, but you mean GCWR gross combined weight rating, the GVWR of the truck dictates how much pin weight you could have.
Thanks
Your truck CAN NOT handle that much weight.
A trailer that is 6200 dry will add up fast. Some manufacturer don't include weight of any accesories, propane etc. So as you said 1000lb for gear then water in the tanks 7500lbs would be a fair loaded weight.
8350-7500-600=250lbs so that's all you have left for passengers and other stuff, but then again the hitch assmbly and the sway controller could add up to 200lbs. So unless you tavel alone and only weigh 50lbs'ish you are well over weight.
As for hitch weight, with the weight distribution none of that really matters much, as long as you have at least a class III hitch and the right bars for the tongue weight.
Seems like wind has more effect than the weight, with my trailer loaded it doesn't seem to be any heavier to pull than empty, on highway that is, starting from a light you notice a small difference
And as for tire size as mentioned the 20's are about 33" tall and the 17's are about 32" so that makes the difference in the drive ratio.
Best tow capacity is 17" wheels with 3.92 gears, with 20" wheels typically you should minus 1000 lbs rating, part of that is the load rating of the lower profile tires too.
