Old 02-03-2010, 11:03 AM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
Default Front end fixes
Ok so with my tax money I am replacing my ball joints with Moog parts.(know a place with decent pricing?)
What else should I replace while I am in there?
Old 02-03-2010, 11:06 AM
Rep:1885
Check the track bar, tie rod ends and gearbox for excessive play.
Old 02-03-2010, 04:31 PM
canuckboy's Avatar
canuckboy canuckboy is offline
Vehicle: 1998 Dodge Ram 1500
Trim Level: None
Rep:114
canuckboy will become famous soon enoughcanuckboy will become famous soon enough
Glad to hear your sensible and going with one of if not the best front end component part companies out there. MOOG rocks and you can beat a lifetime gaurentee
Im halfway there, replaced my original lowers and link pins with Moog parts. Just waiting for the original uppers to start having play and I will be tossing/pressing Moogs into there also
But ya pretty much any moving joint under there can be replaced with Moog eh. Although I know the pitman arms can be quite a bit more than the regular aftermarket ones or OEM. I replaced mine but went with an OEM one because the MOOG was twice as much.
Anyways Good luck and have fun....
Old 02-10-2010, 10:07 AM
Rep:1930
Well I can no longer get the Moog parts I was planning on. With my ankle injury gonna have some medical bills to pay, since I don't live in Canada, and my works health insurance is horrible, even though I work for an insurance company.
I found on ebay where they have a 1 year warranty and come with tie rods and something else for $166 free shipping too. These should hopefully be good for now, and then can replace with Moog next time. I know I shouldn't but money is tight so I gotta do what I have to.
Old 02-10-2010, 10:31 AM
www.rockauto.com
Old 02-10-2010, 11:20 AM
Rep:1885
You might consider only replacing the parts that need replacing with Moog instead of rebuilding the entire front end.
Old 02-10-2010, 11:36 AM
Rep:1930
I might do that Randy. I know one ball joint is bad, can't remember which one, but it had about an 1/2 to 1 inch of play. The other side was good, do I just change the one peice that is bad (top or bottom) or should both be done to match (top/bottom and/or left/right)?
Old 02-10-2010, 11:57 AM
Rep:1885
If you only have one bad joint on one side, I'd do both if finances permit. That way you wont have to tear it back down again to do the other. If there is one bad on either side and finances wont allow replacing all four, then fix whats bad with good parts and make sure the bearing surface and inside the knuckle has been cleaned of all rust and coated heavily with antiseize so you can take the bearings back out without damaging them.
Old 02-10-2010, 12:05 PM
Rep:1930
Great thanks, I think I am going to check into that route. I have a paper with what needs to be fixed on my front that I received from Car-X at home somwhere.
Old 02-10-2010, 03:36 PM
bones64's Avatar
bones64 bones64 is offline
Trim Level: slt/sport (bones)
Rep:659
I agree with Randy , Werm. If ones bad the other is coming soon i imagine. I would do them and anything else you are sure of. I feel for you about your health care bills.It does suck. All the best.
