Old 02-03-2010, 11:29 PM
Travis Travis is offline
Vehicle: 2014 Ram 2500
Trim Level: Outdoorsman
Travis is on a distinguished road
Default To swap or not to swap...that is the question
I have a 99 dodge ram sport quad cab. The truck has a rebuilt auto trans, aftermarker trans cooler and new trans lines. The truck also has a 3 inch suspension lift. I have 2 questions. First, will the flywheel and torque converter from a 95 360 fit a 99 360 engine? Second, my truck needs an engine, originally it had a 5.2 in it, but have been going back and forth about putting in a 360. Do you guys recommend this swap? The truck will be mainly used for on road, and the occational offroad adventure. I will be putting 33x12.50 tires on the truck, and it has a rear gear of 3.55. I would like to be able to tow a car trailer with my trans am on it to drag racing and auto x events, so I want something that has decent power. I didn't know whether it would be better to just go with the 5.2 and put an intake on it with headers (truck already has mandrel bent dual exhaust with hooker air chamber muffler) or put in the 360? I want something that will be a good all round truck. Any help would be great.
Travis
Old 02-03-2010, 11:50 PM
Rep:1845
I'd go with the 360 since you have a middle of the road gear, you're going with larger tires and plan to tow a car. I'm not sure about the flywheels interchanging.
Old 02-04-2010, 12:03 AM
Yeah, I'd go with the 360..more HP potential!
Old 02-04-2010, 11:51 AM
ScatPak07's Avatar
Rep:970
Sound like the 360 would be a pretty cool addition. If you have the cash then why not
Old 02-04-2010, 12:05 PM
bamataco bamataco is offline
bamataco is on a distinguished road
I would go with the 360. For towing what you need is ore torque. More cubic inches brings more torque and the possiblity of moding to bring even more torque. Taller tires will actually be a bad move as far as towing goes. It in effect will change your geat ratio in the wrong direction. You should change to lower gears(higher numerically) if you want to run taller tires. Something like 4:56's.
Old 02-04-2010, 03:42 PM
wvcoolvinilla wvcoolvinilla is offline
Vehicle: 2011 Ram 1500 Outdoorsman 4x4
Trim Level: Outdoorsman - Rambox
Color: Black Crystal - Gray
Rep:83
wvcoolvinilla will become famous soon enough
I had the 5.2 in my 97 and pulled a boat and trailer (5200 lbs) in the mountains of WV with no problems.. I had stock 16" wheels with 285/65. I had 3.92 installed with ni ill effect to my milage form the 3.55's.
Old 02-04-2010, 03:45 PM
98sst's Avatar
98sst 98sst is offline
Vehicle: 1998 Dodge ram 1500
Trim Level: SS/T
Rep:883
hell, 408 stroker! Lol
360 man, all the way.
Old 02-04-2010, 03:48 PM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
No real difference in fuel economy between the two, so there's no advantage to the smaller engine, either.
Old 02-18-2010, 12:09 AM
after looking the specs up, the 318 has only 15 fewer hp, but 45 less torque. Would a CAI, and a set of headers on the 318 make up this difference?
Old 02-18-2010, 12:44 AM
Rep:2616
or you could really upgrade heheh evil grin
http://www.moparmagazine.com/2009/no...e_engines.html
