Cold starting the Cummins - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Old 02-04-2010, 12:16 AM
2nd Ram's Avatar
2nd Ram 2nd Ram is offline
Vehicle: 2009 Dodge Ram 1500 4X4
Color: Black/Gray
Rep:14
2nd Ram is on a distinguished road
Default Cold starting the Cummins
How are you guys getting along with your older Ram diesels and their ability to start in cold weather? I'd guess a brand new one would start without any problem, but how about after a few years? Do they have to be plugged up every night, or maybe are you having to replace glow-plugs more frequently than you'd like. Do these newer generation Cummins engines even have glow-plugs? My '96 Powerstroke absolutely has to be plugged in overnight if I expect it to start the next morning. This is a pain and a problem if I plan to be out somewhere overnight. Just curious if there have been improvements since I bought in '96. Thanks for any input.
Old 02-04-2010, 10:50 AM
ltdan ltdan is offline
Vehicle: 2016 Ram 1500
Trim Level: Lone Star
Rep:36
ltdan is on a distinguished road
No glow plugs on the newer trucks. My '03 with 215K miles starts fine, although it doesn't get as cold here as a lot of places (Central Texas). Just make sure you keep the batteries up, it takes a lot of amps to turn that beast over with all the compression of a diesel (hence the reason you have two batteries). And replace the starter when it gets weak.
Old 02-04-2010, 10:57 AM
Resident Technician
Rep:1915
Don't forget to drain the water out of the filter and add an antigel treatment to the fuel when it's going to be below freezing for very long.
Old 02-04-2010, 08:58 PM
2nd Ram's Avatar
Color: Black/Gray
Rep:14
So the new Ram Cummins doesn't have any glowplugs at all? Do they still have block heaters that have to be plugged up?
Old 02-04-2010, 08:59 PM
Resident Technician
Rep:1915
They have a cold start setup but it's not glow plugs and they have block heaters as well.
Old 02-04-2010, 09:19 PM
Snowman's Avatar
Snowman Snowman is offline
Vehicle: 2010 Cummins 3500 Crew cab
Color: White/two tone
Rep:34
Snowman is on a distinguished road
My new Cummins starts right up at -10 without being plugged in to block heater. New gen diesel all start up with no smoke and hardly any noise. My Duramax ( just sold it) has no-wait time to start even when it's below zero . I love the new super quiet Cummins,awesome low rpm torque and really usefull exhaust brake controlled wwith the Variable Turbo set up. 19 MPG and still only new (1200 kms).
Old 02-04-2010, 10:49 PM
Rep:3347
A lot of the older Cummins I see in the oil patch start up no issues. These guys run conditioner, plug in the block heater everynight, and cycle the plugs. Now their welders... I can't say the same... they take a mean fight to get going if they forget to plug them in.
