Old 02-04-2010, 04:14 AM
rustyolred's Avatar
rustyolred rustyolred is offline
Vehicle: 1997 Ram 1500 ext cab 4x4
Trim Level: Laramie SLT
Rep:20
rustyolred is on a distinguished road
Send a message via AIM to rustyolred
Default Loose mirror fix
Is there a way to fix a loose door mirror? Mine just rotates freely and won't stay put.
Old 02-04-2010, 09:18 AM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
Do you have a pic of how the mirror looks so we can see where it swivels or better description?
I may have a suggestion depending on where.
Old 02-04-2010, 09:42 AM
Is it the whole housing or just the glass portion?
Old 02-04-2010, 12:05 PM
rustyolred's Avatar
Rep:20
it is the mirror itself right where the mirror attaches to the door. look at this pic, it is where the "rod" goes into the door.
Old 02-04-2010, 12:15 PM
Rep:1930
Automotive adhesive, you can get it at the auto parts store. It holds up to the elements and bonds with plastic
Old 02-04-2010, 12:24 PM
rustyolred's Avatar
Rep:20
will mirrors from a 98-02 fit? I know they are a different design, but if you change out the whole thing, would it work?
Old 02-04-2010, 01:41 PM
Rep:1930
yes they should fit too
Old 02-04-2010, 03:52 PM
barracudadave67's Avatar
barracudadave67 barracudadave67 is offline
Vehicle: 1999 Dodge ram 1500 4x4
barracudadave67 is on a distinguished road
Underneith the door panel there are two or three nuts, that hold the mirror on. Check those they might be loose. Or you can tighten up the screws, that hold the chrome "pipe" in place. If tightening the pipe screws dosn't work you can put in another piece of plastic shim to tighten the pipe. There are four screws that hold the pipe. To get to the pipe screws, remove the 'chrome outside cover', their is an allen screw on the bottom of it. Then slide the cover out of the way the best you can.
barracudadave67 aka Dave C.
Old 02-07-2010, 01:13 PM
1997ram1500 1997ram1500 is offline
1997ram1500 is on a distinguished road
hello, there is actually a tsb thats addresses this problem the tsb is number 08-30-99
here is a list of the parts that the tsb requires. if you go to a dealer they should have no problem printing the tsb for you so that you have the repair instructions.
(1) 05016568AA Mounting Kit, Outside Power Mirror, Right Side
(1) 05016957AA Mounting Kit, Outside Power Mirror, Left Side
(1) 05010901AA Reinforcement Bracket, Left (Driver Side) Outside Power Mirror
(3) 00153912 Screw, 0.190-16 X 0.50 in. Self Tapping
(1) 82300234 Mopar RTV Sealant
Old 02-07-2010, 05:10 PM
eph1zzle eph1zzle is offline
Gender: Not Specified
eph1zzle is on a distinguished road
if its a tsb shouldnt the dealer fix it ?
