Old 02-04-2010, 03:31 AM
joshuakline joshuakline is offline
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
joshuakline is on a distinguished road
Default 2006 Dodge Ram 2500 turn signal problems
Hi i have a 2006 dodge ram 2500 turbo deisel regular cab long bed truck
here is my problem my front passenger side turn signal does not work i am not getting power to it the rear signal works but it does blink fast i am hoping someone else has had this problem and knows the right way to fix it please let me know thanks
joshuakline@yahoo.com
Old 02-04-2010, 08:21 AM
Rep:1885
Have you checked to see if you're getting power to the r/f signal?
Old 02-04-2010, 09:48 AM
there is no power to the front right.
that is the only one not working
Old 02-04-2010, 10:04 AM
Rep:1885
Judging by what I see in the wiring diagrams, you probably have a bad driver in the TIPM for the r/f signal lamp.
Old 02-04-2010, 04:20 PM
do you mean a software driver if so what would that mean to fix
Old 02-04-2010, 04:25 PM
Rep:1885
Unfortunately it's not a software issue but rather an electrical problem that may require TIPM replacement. You should check the r/f wire coming out of the TIPM for voltage. If you have it there, you're looking at a wiring problem; if not, you're probably looking at a bad TIPM.
Old 02-04-2010, 06:23 PM
off hand do you know what wire it is and where it comes out of the tipm
Old 02-04-2010, 06:37 PM
Rep:1885
You'll be looking for the WT/TN wire located at pin 2 of the C5 connector. in the TIPM.
Old 02-04-2010, 08:01 PM
sorry for all the questions but this is my first dodge do i have to take the tipm out to check that connector
Are the tipms really about 600 dollars?
