Old 02-13-2010, 08:52 AM
rickerred's Avatar
rickerred rickerred is offline
Vehicle: 2011 Sport
Rep:43
rickerred is on a distinguished road
I also live in cold winter Canada, a block heater is mandatory on Canadian vehicles, however as stated in previous posts you do not entirely need one. Wind chill will not make a big difference as the engine is blocked from most of the wind. A block heater will allow your truck to warm more quickly and keep your oil more fluid allowing it to flow more easily at cold temps , but the oil in your truck should be fairly thin any way. For a better explanation try this site.
http://www.machinerylubrication.com/...scosity-limits
Mods: Garmin GPS, Trifold Tonneau Cover, Molded Mud Flaps, K&N Cold Air, Westin Oval Step Sides, Vent Visors.
Future Mods: What ever I can sneak by my wife.
Old 02-13-2010, 08:12 PM
weeseekase weeseekase is offline
weeseekase is on a distinguished road
We had a few days in December where the temperature dipped as low as -48c. I never plugged mine in and it started just fine.
Old 11-03-2010, 05:34 PM
swedishram swedishram is offline
Vehicle: 2002
Trim Level: quadcab
swedishram is on a distinguished road
- where do i find a blockheater for my 5,9L 2002 ?
- is it difficult to mount by myself ?
Old 11-24-2010, 06:40 AM
Vehicle: 2002
Trim Level: quadcab
lifting the thread again !
iv been looking for a blockheater but it seems hard to find only for the diesel engines !
and in we in europe use another voltage than in US, 230 volts 50 Hz !
will it not be possible to us the us heater here ?
Old 11-24-2010, 06:47 AM
kot333 kot333 is offline
Vehicle: 2010 Dodge Ram 2500
Trim Level: TRX4-OFFROAD
Color: Blue
kot333 is on a distinguished road
Hi, is it 220v in sweden?
In russia 220. so with heater i bought 220-110v converter, 1kw its enough.
About installation - takes 15 minutes.
Old 11-24-2010, 12:36 PM
ken99 ken99 is offline
Vehicle: 2010 Ram 1500 Crew 4x4
Color: Austin Tan Pearl
Rep:26
ken99 is on a distinguished road
Wind chill has no effect on a cold engine or any other inanimate object. A cold engine at -20 is -20 regardless of what your body experiences.
Old 11-24-2010, 04:56 PM
Otterdriver's Avatar
Otterdriver Otterdriver is offline
Vehicle: 2013 Big Horn Crew Cab
Color: Western Brown Pearl
Rep:160
Originally Posted by MasterBlaster View Post
I am picking up my new Big Horn Ram today. I noticed in the window sticker that no engine block heater is listed.
1.If the heater is installed, is it normal for it to be shown on the window sticker?
2. Can a dealer installed the heater or is this only factory installed?
3. With the new engine do you really need an engine block heater? (I will be traveling to Bountiful, Utah in 2 weeks. Brrr):
Originally Posted by bones64 View Post
Hello. I have one on my 2003 ram. I have never used a block heater for it or actually anything i have ever owned. I live in Ontario, Canada and it gets pretty cold up here. Never needed it. I too say not to bother but if something you want sure. Its not a big job.
Not sure if you would need one in Arizona, Bones 64, wow, you live in Ontario and you don't use a block heater, that sounds like an iminent torture test to me.
Old 11-24-2010, 05:26 PM
Aries's Avatar
Aries Aries is offline
Vehicle: 2010 Dodge Ram 1500 Quad Cab
Aries is on a distinguished road
I live in Montreal where the winters are pretty cold, And I've never used a block heater on any of my cars. I had the hood opened on my Ram the other day and noticed I have a block heater. That said, I don't think I'll be using it. With the remote starter I don't need it.
Old 11-24-2010, 05:32 PM
Talayoe's Avatar
Talayoe Talayoe is offline
Color: Blue
Talayoe is on a distinguished road
I live in Edmonton, AB. This past week we have ranged from -20c - 37c. I park my truck outside and have had zero issues with it starting. Does it take longer to heat? I really cant say cause I let it run for 10 or so before I get in.
Too bad plugging the truck in doesnt keep the leather seats and steering wheel warm otherwise mine would always be plugged.
Another option, if you dont want the block heater, get an aftermarket car starter with a temp sensor on it. I dont have this, but have on previous older vehicles. Its great. You set the temp. for when you want the vehicle to start. I had mine set to run every 3 hours for 10 minutes when the temp hit -30c or lower. Used a little more gas...but good comfort back then knowing the truck would still start in the morning (even tho it was plugged in).
Old 11-24-2010, 06:21 PM
AKFossil's Avatar
AKFossil AKFossil is offline
Vehicle: 2010 Dodge Ram 1500 Crew Cab
Color: Inferno Red
Rep:57
AKFossil will become famous soon enough
I use block heaters and live by them. Yes you do not need a block heater when its 10 to 20 below BUT it does help and is easier on your vehicle. And if you are a environut it reduces the pollution your vehicle spits out at initial start-up during cold periods.
What I do is hook a timer to my outside outlet and then set it for 2 hrs prior to me leaving for work, so if I am running late, or on time the engine will be ready.
2010 Dodge Crew Cab Inferno Red: HID Low Beams & Fog Lights 6000K, LED Interior Lights, LED License Plate Lights, Black Nerf Bars, AVS Bug & Window Deflectors, K&N Drop In Filter, WeatherTech Floor Mats, Goodyear Wrangler Silent Armors, MagnaFlow Muffler
Thinking about: New Wheels, and leveling kit.
