Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel
Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel Discuss modifying your Dodge Ram with Performance Parts and Accessories!
United Radio
Old 02-04-2010, 03:20 PM
iRESQu iRESQu is offline
Rep:2217
Question Which fuse is the Accessory fuse on 6.7?
Ok, yes the question may seem simple but this is my FIRST electrical try. My husband got me a Bully Dog Triple GT tuner for my 08' 6.7 Cummins. I can do a direct power feed off the OBDII but then I have to manually shut the Dog off every shut off, as opposed to power wiring it. I am choosing to power wire it. The installation guide directs you to find the Accessory fuse and spade/tap it. I don't know which fuse is the Accessory one. I have referenced my owners manual, but I didn't see it.
Whatcha think?
Thanks,
Paris
Old 02-04-2010, 03:40 PM
Rep:1845
You wont find one. What you're looking for is a fuse with power on in the accessory/run position.
Old 02-04-2010, 03:59 PM
Rep:2217
Yes! That too......I think. Maybe I am getting in over my head. I read the chart in my owners manual and it is Chinese to me. Then I have a friend telling me I should stay out of my wiring harness and run a feed wire from the battery. I don't know how to tell which fuse is a power on fuse. So then it says something about a voltmeter. Wow, the fender flares were so much easier.....What is the first electrical thing a TOTAL rookie should start with, other than changing a battery?
By the way, thank you.
Old 02-04-2010, 04:48 PM
Rep:1845
In your case, a test light would be easier to use for finding a switched 12V source. If you look closely at the fuses you'll see a very small metal tip on either side of the number on it. Connect the clip on your test light to a good metal ground and probe those tips with the key on and the key off to determine which ones are on with the key. If you're the least bit uncomfortable with tackling electrical work, let a professional do it.
Old 02-04-2010, 05:16 PM
Rep:2217
I found a power ign 10 amp fuse that works with power on/off. I appreciate your help. THANK YOU VERY MUCH, and my disclaimer.....
I know that it is solely on me to verify all I am told.
I trust ya!
Thank you so much!
Paris
Old 02-04-2010, 11:18 PM
sablefish's Avatar
sablefish sablefish is offline
Vehicle: 2013 ram sport
Trim Level: sport
Color: red
Rep:78
sablefish will become famous soon enough
I tapped into the cigar lighter fuse when I installed my bully dog. It has power only when the key is on.
2013 ram sport, 8 speed. pace edwards full metal jack rabbit tonneau, bed slide 1500cg bedslide, husky weatherbeaters
Old 02-05-2010, 07:15 AM
Rep:2217
Thanks again guys. I started to feel overwhelmed as I am not into, nor do I understand, electronics AT ALL! But it really is quite simple once I got in there and started working.
I really appreciate your help.
Paris
Old 02-05-2010, 09:24 AM
Rep:1845
I guess that means nothing has been set on fire and the airbags haven't deployed.
Old 02-05-2010, 10:43 AM
Rep:2217
Randy and Sablefish,
I appreciate all your input. I was set to wire it to the 10 amp hvac but then my neighbor, a F**d service mgr, came over to "help" and told me if he sees this (evidence of a programmer/tuner) on one of his customers trucks, he will deny work to it. His suggestion, find an accessory wire within the cab to tap into. Stay out of the engine bay. So my husband now feels I should run it off the OBDII until he gets home and we can go through the cab together. Is it true and is THAT big of a deal made over having these programmers/tuners in your vehicle when it comes to warranty?
Again, thank you so much!
Paris
Old 02-05-2010, 11:00 AM
Rep:1845
Yeah, if they catch a tuner on it and can relate it to a problem it could have contributed to, they can deny the warranty claim. We've never refused to work on one but it could become a customer pay issue. As Sablefish recommended, the power outlet is a great place to tap into as long as you don't have a ton of other things plugged into it that could cause the fuse to repeatedly blow. The down side to that is that sometimes cheap made/defective accessory plugs will cause the fuse to blow and your tuner could go dead while driving down the road.
