Old 02-04-2010, 05:48 PM
JoeJoe09's Avatar
JoeJoe09 JoeJoe09 is offline
Vehicle: 2002 Dodge Ram
Trim Level: 1500 SLT 2WD
Color: Gold (almond)
Rep:77
JoeJoe09 will become famous soon enough
Default 6" lift, 35" tires.. Should i?
OK for the longest time I've wanted to lift my truck.. But money has been an issue. Now I'm to the point were i am able to do this if i wanted to. But my issue is do i want to spend a lot of money on my truck, or buy a newer one. Here are all the specs and info!
My truck is a 2002 Dodge Ram 1500, SLT 2wd. It has about 91,500 miles on it and it has the 4.7L V8.
There are some mechanical problems that need to also be repaired. (Front seal leak, Radiator leak, left turning knuckle, and tranny seal) all about $1800 total. But only the first 2 need to be done as soon as possible.
Work that i want to get done on it
Rough Country 6" Lift kit
(link to it lift kit) http://www.roughcountry.com/dodge_2wd_02-05_6.html
XD Spy wheels 18x8.5
(Picture of a dodge with XD Spy wheels 00364.jpg)
35/12.5/18 Trail Grapplers by Nitto (their newest ones)
(Picture of a dodge with these new tires 129_0912_02_z+nitto_trail_grappler_mt_tire+dodge_ram_2500.jpg)
Spray in bedliner
All around window tinting
All around spending $4500 just for upgrades.
Im asking if you think its worth it to keep my truck and keep her going and modded up. Or settle for a stock newer car or truck.
Please let me know what you think, i want to do something this month.
Old 02-04-2010, 07:36 PM
foxcrazy90's Avatar
foxcrazy90 foxcrazy90 is offline
Vehicle: 2008 dodge ram 1500
Color: electric blue pearlcoat
Rep:584
foxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to all
which way would you be happiest? newer truck stock or big cool looking lifted truck?
you need to fix all the problems first! have you looked at newer ones or even the same year with lower miles and already lifted.its a really tuff decision!!! good luck!!!
NEIL KELLEY
2008 ram 1500 bighorn 4x4
2 1/2 level lift--hella 500ff grill lights--17x9 centerline grizzly-305-70-17 nitto terra grapplers--front air valance removed--tinted windows--custom audio system clarion vz401 head unit--pioneer 4channel amp and class D mono amp--memphis mclass door speakers--clarion dash speakers--kicker subs
Old 02-04-2010, 09:22 PM
2nd Ram's Avatar
2nd Ram 2nd Ram is offline
Vehicle: 2009 Dodge Ram 1500 4X4
Color: Black/Gray
Rep:14
2nd Ram is on a distinguished road
Man, that's a tough call. Just my opinion, and yours is the only one that counts, but I wouldn't want a lifted truck unless it was a 4X4. I like 2X4's lowered. Looks like the Rough Country kit comes with a three-inch block for the back. Once you remove the leveling kit you now have, and install the new front six-inch spring, you'll still only be sitting three inches higher than you are right now. Something else you might consider is that your 4.7 engine is gonna struggle a bit more to turn those 35's over. This effect will be even more noticable if your truck has a high geared rear end. Now could be a good time to trade for a newer truck before yours turns over 100K miles. You've really got lots of miles left in your truck, but the 100K thing will hurt its resale/trade-in value.
Old 02-04-2010, 09:39 PM
I push the skinny pedal
Rep:3308
I'd have to agree with 2nd Ram on the 4x4 and 4.7L not making enough power. I'd recommend a newer truck, or a similar year truck with a 5.9L cummins
Kurtis
Old 02-05-2010, 11:28 PM
ScatPak07's Avatar
Rep:970
This is really a preference. If you want a unique vehicle thats your own or get a new every one has vehicle.
i do have to agree with Cdnoil if you had the 5.7L then i would say keep it but the 4.7L dosn't quite cut it in my books. If you have the money to buy new then why not get a mroe powerful one. If you are happy with the power your truck has then keep it and make it your own
Old 02-05-2010, 11:39 PM
Rep:1625
That really is a tough call. The ball is in your court. Do what makes you happy.
Old 02-05-2010, 11:43 PM
I'm not sure I'd do the lift and 35's . I've heard alot of complaints about not enough power and trans downshifting all the time . If your sure you want to do it . I would recommend regearing the truck for the tire size .
