Upper Glove Box - Page 4 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 09-14-2011, 03:09 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
I'd actually rather have the open box lol...
Sean
Old 09-14-2011, 05:13 PM
RAMitDOWN's Avatar
RAMitDOWN RAMitDOWN is offline
Vehicle: 09 Dodge Ram
Trim Level: ST 4X4
Rep:24
RAMitDOWN is on a distinguished road
To bad you weren't around before we could have made a trade.
Old 09-20-2011, 01:34 PM
RAMitDOWN's Avatar
Trim Level: ST 4X4
Rep:24
Looks like I celebrated prematurely..........
As you can see from the picture it's not going to fit the tab on the truck is between the two screw holes but the slot on the lid is above the two holes.
Just spoke with the seller of the glove box it came from a 2500 and is going back.
Old 12-12-2011, 12:33 PM
Combatmedic313's Avatar
Combatmedic313 Combatmedic313 is offline
Vehicle: 2015 Ram 1500 Big Horn
Combatmedic313 is on a distinguished road
You wanna trade, Snrusnak?
I feel like I'm diagonally parked in a parallel universe!
Old 12-12-2011, 12:35 PM
snrusnak's Avatar
Rep:1388
Somebody else actually asked me a while back, and although I'd rather have the open box, I am not really interested in changing it or messing with the dash at all. I'm fine with either, just that if I was buying a new truck and had the option I'd probably get the open one.
Sean
Old 12-12-2011, 12:42 PM
Its all good. Had to try, right?
Old 12-13-2011, 09:52 PM
NMBowtie's Avatar
NMBowtie NMBowtie is offline
Vehicle: 2015 Ram 1500 CC 4x4
NMBowtie is on a distinguished road
I did the upper glove box mod to my ST a few weeks ago. It was pretty easy actually. I found a local wrecking yard with several 4g Rams in it, and was able to pick and pull parts from several to do several mods including the glove box. I didn't take pics since I was doing it in their parking lot, but I ended up getting the parts for $30 which I thought was a steal! All I need to do now is find a 12v wire to tap for the light.
Also, RAMitDOWN, that glove box you had would have fit. The one I installed looked like that, and was a total PITA to get the hinge tucked up inside the dash behind the top cover, but that notch actually rests on top of the tab you see with the screw holes lined up behind the holes in the dash. I know this is probably too late, but if you find another one, it will work.
Before: You can just barely see the open compartment.
After: New glove box, cluster, steering wheel with controls, etc.
Old 12-13-2011, 09:58 PM
snrusnak's Avatar
Rep:1388
NMBowtie:
Looks good, and at a steal! Would you mind posting pics of your door panels? I want to compare to mine...
Sean
Old 12-13-2011, 10:15 PM
NMBowtie's Avatar
Not a great pic, but you can kind of see how it looks. They are a solid dark grey with the lower storage pockets, but without the upper ones just below the door pull.
Old 12-13-2011, 10:18 PM
snrusnak's Avatar
Rep:1388
Thanks that's perfect. I don't need or use that upper storage tray anyway, it's pretty useless IMO... So it's a 100% solid plastic door panel right? Mine has padded arm rests and they are wearing out fast, and I was thinking if I can swap to the "lower" end ST model door panels they will hold up better if they don't have the padded arm rests. I also wasn't sure how the solid black color would look with the tan dash as my door panels are multicolored to match the dash, but it looks just fine IMO. And you still have all four window controls and the mirror controls on the driver door right? Just to be sure the tray will fit the door panel...
Sean
