Old 02-06-2010, 12:52 PM
348 red ram 348 red ram is offline
348 red ram is on a distinguished road
Default Question about behind the grille lights
Hi all,
About the behind the grille lights....I have an 09 Ram sport w/ a Hemi an a honeycomb type grille. I was thinking of putting in a set of KC hilights- the DAYLIGHTER series, they're 6" stainless models that throw out 385,000 candle power in a long range pencil beam form... person at KC says they light
up almost a mile down road. My question is to the people that have behind the grille set-ups is; does the grille cut off the light source, difusing or in my case cutting off the long range or pencil beam effect ?
348 RR
Old 02-06-2010, 02:46 PM
bones64's Avatar
bones64 bones64 is offline
Trim Level: slt/sport (bones)
Rep:659
I can only say on previous experience. The lights behind the grill do not really get cut down from the grille if thats what your getting at. I have had a few trucks with them installed behind the grill. I had no problems.
Old 02-08-2010, 05:30 PM
Brute's Avatar
Brute Brute is offline
Vehicle: 2009 Dodge Ram 1500
Rep:56
Brute will become famous soon enough
I was thinking about doing this mod this morning while I was driving in to work. I will have to give it some thought.
Old 02-08-2010, 10:40 PM
Smitty's Avatar
Smitty Smitty is offline
Vehicle: 2009 Dodge Ram 1500 4 x 4
Smitty is on a distinguished road
I have 4 - 10W LED's behind my grille, didn't notice any drastic drop in light output on the road compared to testing without the grille. I don't think you would run into any problems with a spot type beam, however a flood beam pattern may be slightly cut off by the edges of the grille depending on how deep they are mounted.
Old 02-09-2010, 01:47 PM
Indianasharps Indianasharps is offline
Vehicle: 2009 Dodge Ram 4x4
Indianasharps is on a distinguished road
Any pic's you can post?
Old 02-11-2010, 04:31 AM
Smitty's Avatar
The lights are Vision-X Solstice Solo's which are 10 W LED's rated at 900 Lumens each. They are 2" square and can be bolted together in a modular format so you can always add more lights later if you want greater output. Thought I would give them a try since they are small and my friend just started carrying the product line so I got a good deal.
