Old 02-06-2010, 08:03 PM
metalmech's Avatar
metalmech metalmech is offline
Vehicle: 2005 Ram Quad
Color: dark grey metallic
metalmech is on a distinguished road
Default Stereo upgrade
well after weeks of flip flopping i have finally decided to got with jl slash amps and components. specifically 300/4v2 and 500/1v2 and not sure if i am going to use the zr up front and c5 in the back or all c5s. but my question is can i use a 4 gauge wire to a distribution block and 8 gauge out to those amps or should i use all 4 gauge? ground included. my dist block can go 4 in and either 4 or 8 out. what do you all think?
Old 02-06-2010, 09:29 PM
Resident Technician
Rep:1909
You can use the equation Amps = Watts/Volts and then figure out what size wire you'll need. The installation instructions for the amps will also recommend the proper wire gauge.
Old 02-15-2010, 10:43 AM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
I would run a 2ga or so to a distro block w/ 2-4 ga coming out
Old 02-15-2010, 11:15 AM
metalmech's Avatar
cool,thanks
Old 02-15-2010, 11:22 AM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Are you planning on a big three upgrade?
Old 02-15-2010, 06:52 PM
metalmech's Avatar
not planning too. do you think i should? i am not going for any competition stuff, just a good system.
Old 02-15-2010, 07:36 PM
chithead's Avatar
Rep:2078
I'm planning on it. When it happens, I'll take pics. Then you can decide
Old 02-15-2010, 07:47 PM
metalmech's Avatar
ok thanks
