Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 02-06-2010, 08:51 PM
tmerritt530's Avatar
tmerritt530 tmerritt530 is offline
Vehicle: 2004 Ram 1500 4.7L "H/O"
Color: Graphite Metallic
Rep:91
tmerritt530 will become famous soon enough
Default Steering pulls left under power
When I point the wheel straight the truck drives straight, but when I am accelerating it pulls the wheel left about 10 degrees. The wheels turn the corresponding amount to the steering wheel's movement. I have gotten used to it and correct it almost without noticing but now I am ready to do something.
what do you guys think I might check?
2004 SLT RCSB 4.7L | 3.92 | OEM Off-Road wheels | Goodyear SilentArmor 285/70R17's | dumped magnaflow | H/O cams | H/O cyl heads | 10" Rockford Fosgate P1
Old 02-06-2010, 09:03 PM
Snowman's Avatar
Snowman Snowman is offline
Vehicle: 2010 Cummins 3500 Crew cab
Color: White/two tone
Rep:34
Snowman is on a distinguished road
Check front steering components for any looseness. If everything seems tight, check for proper tire pressures and roate tires to see if pull goes away or pulls differently. If all is good check alignment.
Old 02-06-2010, 09:05 PM
Rep:1845
Thrust angle, u-bolts on the rear end, front suspension and steering.
Old 02-07-2010, 12:07 AM
strang3majik's Avatar
strang3majik strang3majik is offline
Vehicle: 1996 Dodge Ram Indy Pace Truck
Trim Level: Indy Pace Truck
Color: Blue w/ white stripes
Rep:210
strang3majik has a spectacular aura aboutstrang3majik has a spectacular aura aboutstrang3majik has a spectacular aura about
in 2wd or 4wd, or doesn't matter?
98 Jeep Grand Cherokee 5.9 Limited / 96 Dodge Ram Indy Pace Truck / 87 Dodge Charger GLHS / 85 Dodge Omni GLH
Old 02-07-2010, 12:32 PM
Rep:91
2wd. Haven't been using 4x4 because I am trapped in the city for now
Old 02-07-2010, 11:39 PM
Rep:210
nevermind then
I was going to say, sure it isn't just the torque steer...but, in 2WD...nevermind...lol
