Driver headlamp out - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Electrical
Old 02-07-2010, 02:51 AM
skubi skubi is offline
Vehicle: 2010 dodge ram 1500
skubi is on a distinguished road
Default Driver headlamp out
I cant seem to find an answer to my problem on the net and hope y'all will be able to help me out. The driver side headlamp on my 2010 Ram1500 is out. I switched bulbs with passenger side headlamp (which was functional) and the "good" bulb did not work when installed on the driver's side headlamp. I checked the engine compartment fusebox for a blown fuse, but couldnt find a specific one for that headlamp. Is there is a secondary fusebox somewhere else that I could check? Any suggestions on other things I should check for?
Thanks!
PS - I have a two headlight system, not a four.
Old 02-07-2010, 02:52 AM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
its under warranty id take it to the dealer
Old 02-07-2010, 05:06 AM
Rep:4376
That's my thought, I'd take it in as well, and someone please correct me if I'm wrong? but isn't there still a fuse box under the driver's side dash? BTW, welcome to RamForumZ since I see this is your first post! Take a moment and stop by the Newbie Checkin and introduce yourself so everyone can welcome you aboard! Good luck!
Old 02-07-2010, 08:14 AM
CHILLZ HEMI's Avatar
CHILLZ HEMI CHILLZ HEMI is offline
Vehicle: 2008 Dodge Ram 5.7L HEMI
Trim Level: Big Horn, Quad Cab
Rep:47
CHILLZ HEMI is on a distinguished road
Send a message via AIM to CHILLZ HEMI
take it to the dealer man....Or, if you know somebody with ALLDATA or SHOPKEY print off a wiring diagram and check it out for yourself...Option 1 would be the best way to go....
Old 02-07-2010, 08:30 AM
Resident Technician
Rep:1915
You won't find a fuse as this is powered and grounded through the TIPMCGW and it could have an internal problem. Take it to the dealer.
Old 02-07-2010, 10:22 AM
Seems like now a days everything is controlled through the ecm .
Old 02-07-2010, 09:24 PM
Rep:3347
I'd have the dealer look for the problem too, since it's under warranty, why bash your head against the wall trying to find it, when someone else gets paid to do that
Also, stop by the newbie section and say hi!
Old 01-07-2011, 01:37 PM
25 Outlaw SST's Avatar
25 Outlaw SST 25 Outlaw SST is offline
Vehicle: 2015 Dodge Ram
Color: Blue Streak
25 Outlaw SST is on a distinguished road
Mine is doing the same thing. The lowbeam will go out and come back on again. already had the bulb replaced onec and it worked for a couple of months and now it is acting up again. Taking it to the dealer on Mon. to have it looked at.
