Old 02-07-2010, 11:16 AM
cainecabe cainecabe is offline
Vehicle: 2003 Dodge Ram 1500
cainecabe is on a distinguished road
Default 4x4 driveline
Yesterday i put my ram in 4 wheel drive, via the manual transfer case 2H/4H/4L shifter. When it was in 4 wheel drive it was causing the vehicle to shake (more pronounced as my speed increased). The shaking make the water bottle in the cup holder shake a lot to give you an idea... it was obvious. Also note; the vibrations almost vanished when all four wheels were on snowy/slippery snow covered roads, then pronounced when on dry parts of road.
Then, right before the highway i pulled over to switch back to 2 wheel drive.
As I entered the highway the 4 wheel drive had not yet disengaged, but i kept on knowing it would disengage in a bit. Then after going 60 for about 1/2 - 3/4 a mile, it we nt BANG BA BANG BANG and i defintly felt it in the cab. Then it was just 2 wheel drive, as that was the 4 wheel drive disengaging. It then drive fine. What I found out when i got to my destination, was that you could hear a clink clink clink clinking to the speed of the vehicle, kinda feel it a tiny bit when going slow in my feet on the flloorboard.
and when i go in reverse it bangs, almost bucking the front end a bit.
Seems like a real problem, does any idea have an idea what could be going on?
2003 Dodge ram 1500 4x4 / 5.7 Hemi, long bed
Old 02-07-2010, 12:02 PM
Rep:1885
Check the u-joints in the driveshaft and axle.
Old 02-18-2010, 05:42 PM
turns out i had busted the ring and pinion in the front diff. ouch.
Old 02-18-2010, 07:16 PM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
that sucks!!!
Old 02-18-2010, 08:00 PM
I push the skinny pedal
Rep:3277
All I can say is ouch. With it not disengaging fully, I'd guess all the drive pressure was on a small portion of the teeth.
Kurtis
