ABS problems - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 02-07-2010, 07:57 PM
Arlon's Avatar
Arlon Arlon is offline
Vehicle: 1996 dodge ram 1500 ext cab
Trim Level: laramie
Color: red
Arlon is on a distinguished road
Default ABS problems
So i just purchased a 96 ram about a week ago and its a pretty nice truck for what i got. Now when i was driving it i noticed the brakes in it were a little rough, so i got it up in the air and took a look at them. They checked out fine except for the drivers side caliper was seized up. so just yesterday i ran some new lines in it and today i just put on new calipers and pads in the front and bled them. The problem is my ABS light is on and it still hasnt gone off even after ive already done what was needed to the brakes. I dont know if theres another problem some where in the braking system that could be bad and i dont know if its even a common problem. Can someone tell me what i should look for?
~USMC~
Old 02-07-2010, 07:59 PM
Resident Technician
Rep:1915
Start by having the ABS module scanned and see what the codes are.
Old 02-09-2010, 10:24 PM
Arlon's Avatar
Trim Level: laramie
Color: red
i already ran an ob2 scanner on it and it didnt say anything about the abs. is there another way i should scan it? because i would really think thats the only way.
~USMC~
Old 02-09-2010, 10:40 PM
Resident Technician
Rep:1915
You need a scan tool that will pull ABS codes. A lot of off the shelf scan tools from parts stores only pull generic OBD II codes from the PCM.
Old 02-09-2010, 10:45 PM
Arlon's Avatar
Trim Level: laramie
Color: red
alright that makes sense because i have a nicer scan tool but i didnt think it would really matter. i guess ill have to try that out tomorrow then.
~USMC~
