Old 02-08-2010, 09:47 AM
rjs2005's Avatar
rjs2005 rjs2005 is offline
Vehicle: 2015 Ram 1500
Rep:35
rjs2005 is on a distinguished road
Send a message via Yahoo to rjs2005
Default Sirius Antenna
Here's hoping the esteemed group here can provide a little assistance. Here's the scenario: I recently replaced the stock single CD/Sirius satellite radio in my 08 with an Alpine IDA-X303 digital media receiver and an Audiovox 700XMALP1 XM radio kit. I got from Crutchfield, and I know there are those who despise them, I've always been quite happy with my purchases through them, in spite of their higher cost. The install was very easy and quite uneventful, until I got to the antenna installation. Not knowing how to remove the factory Sirius antenna, I chose to route the XM antenna around the rear window, through the same hole as the wiring for the Cargo/high center brakelight assembly, and place the antenna on the roof directly behind the Sirius antenna. Here comes the rub: lately, I've noticed that in the morning, when heading east (I do that a lot going to work), I lose my signal. Often, the word "Antenna" will flash on my receiver. I have checked the connections and they are tight and clean. I can only assume that the signal is being blocked somehow by the Sirius antenna.
Here's my question. How is the factory antenna mounted? Does the cable go through a hole in the roof, or is it a magnetic field type setup? Finally, if there is a hole, how big's the hole?
Yes, I know I can figure this all out myself if I drop the headliner, I just don't want to go through all that if the hole's too big for my mini XM antenna to cover up. Hoping one of the experts here have already encountered this situation!
Old 02-08-2010, 09:55 AM
Rep:1885
1.Disconnect and isolate the battery negative cable.2.Lower the rear portion of the headliner as necessary to access underside of antenna.3.Disconnect the antenna cables.4.Remove retaining fastener.5.From inside the vehicle, and using a flat bladed tool, depress one of the retaining tabs on the antenna. Push up the one side of the antenna connector through the roof panel. Depress the other side of the connector and remove the antenna.
Old 02-08-2010, 09:58 AM
Rep:1885
No info is given regarding the size of the opening for the antenna wire to pass through. Is there an adapter that woul allow you to use the factory antenna?
Old 02-08-2010, 10:07 AM
rjs2005's Avatar
Rep:35
To the best of my knowledge no, since XM and Sirius use a slightly different frequency. Thanks very much for the info, I figured if anyone would be able to come through so quickly, it would be you Randy!
Again, thanks!
Old 02-08-2010, 10:31 AM
Rep:1885
If your antenna is a magnet mount, you might try moving it around a bit and seeing what happens.
Old 02-08-2010, 10:43 AM
rjs2005's Avatar
Rep:35
I'm thinking about relocating it, but asthetics are important to me too. Now that I know there's a plug up under the headliner, I'm going to try removing it and see if my existing antenna will cover the hole. A write up and pictures are to follow.
Old 02-08-2010, 09:10 PM
jjhwick119's Avatar
jjhwick119 jjhwick119 is offline
Vehicle: 2004 Dodge Ram Reg cab
Rep:97
jjhwick119 will become famous soon enough
at work we put them in dash all the time with no problems. where the infinity dash speakers would go, theres areas under that piece where a sat antenna can mount
04 Dodge Ram 1500 SLT 2WD. De-Badged
Regular Cab, Black. drop shackles in rear to level
Old 02-08-2010, 10:24 PM
michael99's Avatar
michael99 michael99 is offline
Vehicle: 1999 Dodge Ram 1500
michael99 is on a distinguished road
It sounds like you routed your antenna the same way I did, above the headliner and coming out the third brake light. If so check the wire where the light cover makes contact with it. If you tighten the light too much it will cut into the wire and cause you to loose signal periodically. Mine has done this before, I relly doubt the other antenna is blocking your signal.
1999 Dodge Ram 1500 4X4, 5.9l V8 360, Airaid CAI, Extang Tuff Tonneau, SS Tubular Nerf Bars,
Flowsound single chamber exhaust duals out the rear
Old 02-09-2010, 09:35 AM
rjs2005's Avatar
Rep:35
It's funny you should mention that. That's exactly what I found. It was cutting into the insulation, grounding out the signal. I used some liquid electrical tape to reinsulate the wire, rerouted the cable to exit from the bottom of the third brake light (had a little water intrusion from the original install) and preliminary testing is good. No problem with the drive to work this morning!
Thanks to Randy and Michael99 for their help!
Old 02-09-2010, 09:36 AM
rjs2005's Avatar
Rep:35
I'll have to check that out, that would be a clean install. Do you have to pull the dash or does the grill pop out?
