Old 02-08-2010, 05:13 PM
jvigier's Avatar
jvigier jvigier is offline
Vehicle: 2003 Dodge Ram 1500 Quad Cab
Color: Gray
Rep:40
jvigier is on a distinguished road
Send a message via AIM to jvigier
Default Overheating, no heat in cab, 03 Ram 1500
Hi folks, been working on this for a while now and cannot seem to sort this out.
2003 Ram 1500 4.7 2x4
Started overheating with no heat in cab. Top hose into rad is hot but bottom hose is cold. Changed the stat but no luck there, same symptoms (not to mention the old stat worked just fine in a pot of boiling water).
the radiator drains fine from the stop plug, no leaks anywhere, so obviously not clogged.
I just replaced the heater core last year, as well as the water pump, I would imagine neither are the issue.
Here is the strange thing: when slipped off, both hoses (feed and return) to the heater core had hot liquid in them. Yet no heat in the cab...wth???
ONly thing I can think of at this point is to replace the water pump AGAIN...just looking for some feedback, war stories, shoulder to cry on etc...
Old 02-08-2010, 05:38 PM
Rep:1909
The 3.7/4.7 is notorious for trapping air in the cooling system and causing the problem you're describing. Try this - remove the bleeder plug on the water outlet for the upper hose and the radiator cap. Pinch off the upper hose with a pair of vise grips or something similar. Put a small funnel in the bleeder hole and fill with coolant until the system is full and then remove the pinch off and reinstall the plug. Finish topping off the system at the radiator, start it up and see what happens. This method isn't 100% guaranteed but it works most of the time. If you still have air trapped in the system you'll need to find someone with a vacuum venturi tool that can pull the air out of the system. One more thing, are you sure the poppet valve in the stat is pointing up?
Old 02-08-2010, 05:59 PM
bones64's Avatar
bones64 bones64 is offline
Trim Level: slt/sport (bones)
Rep:659
Good pint Rem. I have done that before regarding the thermostat. What a piss off to find out that was the culprit after alot of angish.
Old 02-08-2010, 07:29 PM
jvigier's Avatar
Color: Gray
Rep:40
Thanks guys, I will definitely try the funnel/bleeder combo Rem suggested!
I will check again on the stat but pretty sure I did that correctly.
I have had to replace MAF, Rad, a/c comp, altntr, both front hubs...too many things to list...here's the thing: weekend before Christmas, with 2 feet of snow in virginia, "tank" got us through even though we were towing a fully loaded trailer...even when the snow plows were getting stuck...so I guess I have to keep him around.
