Old 02-09-2010, 04:23 PM
Emptycreel Emptycreel is offline
Engine: 2004-2004 359ci (5.9L) Cummins ISB 600 24-Valve Diesel I6 325hp 600lb/ft (6-Speed Manual)
Emptycreel is on a distinguished road
Default Warning beep or chime started today . . .
Any reason my 2004 2500 beeps or chimes when I brake? Thanks in advance.
Old 02-09-2010, 06:54 PM
ltdan ltdan is offline
Vehicle: 2009 Ram 1500
Trim Level: Lone Star
Color: Rugged Brown Metallic
Rep:36
ltdan is on a distinguished road
Brake light out, or the connector is corroded. Look to see if a message that says "Lamp Out" flickers on the dash.
That's what mine did when the bulb connector got some water in it in got a little corrosion going on.
Just scrape it out, and put a little grease in there.
Old 02-09-2010, 10:23 PM
ScatPak07's Avatar
Rep:970
Really eh that kinda weird. I think ifdan has the answer there so go take a look
Old 02-10-2010, 08:36 PM
boostaddicted05 boostaddicted05 is offline
Vehicle: 2004 Dodge Ram 2500 4x4
Color: Blue
Rep:17
boostaddicted05 is on a distinguished road
maybe check your fluid level. some cars dash light will come on if they are low
Old 02-15-2010, 12:17 PM
bigdaddyII's Avatar
bigdaddyII bigdaddyII is offline
Vehicle: 2012 Ford F-150
Trim Level: XLT
Color: Metallic Blue
Rep:91
bigdaddyII will become famous soon enough
My truck done that a couple times. Windshield washer fluid was getting low and when I applied the brakes I guess it sloshed enough to trip the sensor.
Sure it'll suck, but it'll make you a man
