My vents wont switch? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Heating & Cooling
Old 02-10-2010, 05:30 AM
sasdelivery713 sasdelivery713 is offline
Vehicle: 2002 Dodge RAm
sasdelivery713 is on a distinguished road
Default My vents wont switch?
my air/heat only blows out of the vents that are pointed at you... It wont blow on the window or the floor... my a/c controls work... as well as defrost... so that isnt the problem... the blower changes speeds... so is there a vent control behind the dash that switches the air flow btwn window, face, and floor?...
2002 Dodge RAM
Ready to Haul 24/7
Old 02-10-2010, 08:07 AM
Resident Technician
Rep:1915
You've probably got mode door/actuator problems.
Old 02-10-2010, 09:32 PM
RAMKING89's Avatar
RAMKING89 RAMKING89 is offline
Vehicle: 2004 Dodge Ram 1500
RAMKING89 is on a distinguished road
^ Sounds same to me
Old 02-10-2010, 09:38 PM
hrafn14's Avatar
hrafn14 hrafn14 is offline
hrafn14 is on a distinguished road
your mode/actuator blend door may be broke or spring inside door that allows it switch through the cycles
Old 04-19-2010, 05:39 PM
rustyolred's Avatar
rustyolred rustyolred is offline
Vehicle: 1997 Ram 1500 ext cab 4x4
Trim Level: Laramie SLT
Rep:20
rustyolred is on a distinguished road
Send a message via AIM to rustyolred
Mine works on both, it just switches between the two by itself. Is this prob caused by a vacuum leak?
Rusty
Old 04-19-2010, 05:42 PM
iRESQu iRESQu is offline
Rep:2217
Randy, wasn't there a recall on this? How would a person be able to verify that?
I might be wrong. I remember one of our other Rams having a recall on this.
Thanks for your help.
Old 04-19-2010, 05:59 PM
Resident Technician
Rep:1915
Which system are you talking about? The older vacuum operated system or the newer electronic system.
Old 04-19-2010, 06:00 PM
Rep:2217
Imma thinkin' 02/03' possibly? Sorry I can't be more precise. I'll keep quiet now.
Old 04-19-2010, 10:36 PM
rustyolred's Avatar
Rep:20
I just need to know where to start lloking for the prob. Like I stated, the dash vents blow......, then it switches automatically to the defroster vents. ???????????????
Rusty
Old 04-19-2010, 11:00 PM
Resident Technician
Rep:1915
Rusty
Yours is most likely a vacuum related problem.
a/c problems, vents
