sqeak in 2001 1500 quad 4x4 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Suspension
Old 02-10-2010, 10:39 PM
cfiiguy cfiiguy is offline
Vehicle: 2001 1500 quad cab 4x4
Color: dark blue
cfiiguy is on a distinguished road
Send a message via Yahoo to cfiiguy
Default sqeak in 2001 1500 quad 4x4
i have the most annoying sqeak in my 4x4. i have tried to isolate it by having the wife drive while i crawl around trying to determine where it comes from. it is definately coming from outside. it only happens when the drive train is engaged. no matter the speed,when slipped out of gear the noise goes away.(automatic) happens in 4WD and 2WD. does not have to be under a load, just in gear. even if your coasting it is there until you pop it out of gear. no matter where you are in the truck it sounds like its coming from the other side. any ideas?!!?
THANKS
Old 02-11-2010, 12:03 AM
I had a squeak type rattle in mine . Was the rod from the column to the trans shifter linkage . When you hear it , apply a little pressure to the shifter and see if it stops . Thats how I pinpointed mine . Good luck .
Old 02-11-2010, 12:52 PM
Color: dark blue
Thanks I'll try next time out
Old 02-13-2010, 09:08 PM
Color: dark blue
didn't help, any other ideas? since i tried this, i have also changed the rear drive shaft ujoints and the squeak is still there while the truck is in gear.
