Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Knowledge Base
Old 02-11-2010, 03:13 PM
RamTech RamTech is online now
Rep:1885
Default Brake Line Flaring How To
Brake line flaring isn't nearly as difficult as some people make it out to be. The savings from replacing just one bad metal line can more than pay for a quality flaring kit like the Matco DFS260 I use.
The Matco DFS260 Line flaring kit. Cost - about $70. Do NOT settle for a cheap $25-30 kit from Sears of your local parts store as the flaring bar and yoke are often cheaply made and won't work well at all. A good set will flare have adapters for 4-5 sizes and will come complete with a tubing cutter.
Begin by cutting the tubing with a cutter. Start with light pressure on the cutting wheel and make one full revolution with the wheel being the leading edge. In this case, I'm turning the cutter away from me. Tighten the wheel no more than 1/4 turn and make another revolution. Repeat until the tubing is cut completely.
Next, ream out the tubing with the reamer on the cutter or other suitable tool to remove any material left inside the line.
Finish prepping the end to be flared by removing any burrs with a fine flat file. Install the tube nut onto the tube and you're ready to make a double flare on the end of the your line.
Start by loosely clamping the line into the appropriate hole in the flaring bar. For this example I'm using 3/16" line, the most common size. The tube should protrude throught the bar and be level with the first step of the flare adapter. Once in position, tighten the wing nuts on the bar and snug them with pliers.
Install adapter into the line and the yoke on top of the adapter. Tighten until the adapter is flush with the cutting bar and then remove the yoke and adapter.
Reinstall the yoke on the bar minus any adapters and tighten by hand until it bottoms out in the line. Remove the line from the bar and you're done.
The finished product should be smooth and even all the way around and almost a perfect circle with the hole in the tubing centered. See, nothing to it!
Old 02-11-2010, 03:48 PM
MightyBlueRam's Avatar
MightyBlueRam MightyBlueRam is offline
Vehicle: 2014 Ram 1500 EcoDiezl Laramie
Trim Level: Laramie 4x2
Color: Blue Streak Pearl Coat
Rep:432
MightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really nice
Awesome write-up Randy! Good work as always.
Old 02-11-2010, 10:41 PM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
Great pics.
Old 10-03-2011, 10:27 PM
spockmckoy spockmckoy is offline
Vehicle: 2002 2500 ram
Trim Level: LT
Color: almond
Rep:19
spockmckoy is on a distinguished road
Exclamation non ferrous brake line tubing
I just ordered it from fedhillusa.com if anyone interested + an assortment of new American SAE nuts.
Old 10-04-2011, 04:13 PM
latitud's Avatar
latitud latitud is offline
Color: Deep Water Pearl
Rep:71
latitud will become famous soon enough
Don't forget to put the nut on the line first....or your first attempt will just be practice..lol
2010 Dodge Ram, 5.7 Hemi, Crew Cab
Old 10-04-2011, 04:20 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
This is great info.....I bought cheap flaring tools in the past and they work terribly....next time I need one I'll buy a good kit...
Sean
Old 04-28-2013, 11:13 PM
Gen1Ram Gen1Ram is offline
Vehicle: 1994 Dodge Ram 2500HD pickup
Color: Blue
Rep:17
Gen1Ram is on a distinguished road
Default Done and Done
This was a process but not too bad for my first attempt.
I took the advice and got the Matco flaring tool kit, works great.
Happened to already have a tubing bender from previous plumbing project, awesome!
So i replaced the two leaking front lines and got everything back together, only to discover a new leak at the rear! moral of the story, replace one rusty line... replace them all!
I ended up snapping a bleeder valve off the front caliper and decided to replace it and the other front caliper as well, both original and rusty as hell, replaced the master cylinder while I was at it cuz i'm crazy like that!
