Old 02-11-2010, 03:37 PM
pojss pojss is offline
pojss is on a distinguished road
Default Shock replacement 3/4 ton
How hard is it to replace the schocks on a 01 3/4ton 4 X 4? Mainly concerned with the front. Rear looks easy enough.
Old 02-11-2010, 04:32 PM
hauser775's Avatar
hauser775 hauser775 is offline
Vehicle: 2001 Dodge Ram 1500
Trim Level: SLT Laramie
Rep:67
hauser775 will become famous soon enough
It is primarily just a couple bolts. 4 on top and 1 on the bottom. The link goes to an install of a leveling kit but it provides pictures of the shock removal.
http://www.trailmastersuspension.com...L220_DL221.pdf
Old 02-11-2010, 04:38 PM
Rep:1909
Old 02-12-2010, 11:37 AM
Great! Thanks! Soon as they arrive I'll get started
Old 03-11-2010, 10:24 AM
jkulysses jkulysses is offline
Vehicle: 2007 Ram Quad Cab
Trim Level: 2500 4x4 HEMI
Rep:68
jkulysses will become famous soon enough
How did this install go because I need to get it done also?? Do you have to re-align the frontend after doing this?
Old 03-11-2010, 11:48 AM
Rep:1909
No alignment is need for shock replacement. If you have any abnormal tire wear, pulling or it's just been a while, you should have it checked anyway.
Old 03-11-2010, 12:05 PM
Rep:68
Ya I need an alignment right now cause it's pulling to the right a little and I just got new tires and don't want to wear them funny but the Bilstein 5100's are on back order and for some reason I thought I would have to realign it after replacing the front ones. So are there any step by step instructions on replacing them? I'm sure I can figure it out I just don't like tearing into things without instructions lol. I'm making the alignment appointment now.
