Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Knowledge Base
Old 02-12-2010, 06:00 PM
marko7717's Avatar
marko7717 marko7717 is offline
Vehicle: 2009 Dodge Ram 1500 Quad Cab
Color: Deep Water Blue Pearl Coat
Rep:92
marko7717 will become famous soon enough
Lightbulb MOPAR T-Shifter Handle Install
I recently ordered and installed a MOPAR t-handle shifter (p/n 82211622), an interior option for the Challenger. Iím sure that this has been posted somewhere before, but I couldnít find it so I thought I would take the liberty. The t-handle sits up a little higher than the old knob by about a half an inch to an inch. Photos and instructions are below.
Cheers
In order to remove the old shifter knob you will have to remove the chrome ring from the bottom of the shifter
(There is no such thing as common sense, so, make sure your truck is not running and the parking brake is engaged when you perform this next step) For ease of removal you will want to move the shifter into neutral. To do that, remove the small tab located next to the shifter.
Once removed, you will notice a red tab inside the hole. Press down on the tab with a screwdriver until you are able to move the shifter. Once you have moved the shifter into neutral, replace the tab back into the hole.
To remove the chrome ring, use a flat head screwdriver and insert it between the chrome ring and the knob. Once itís in there press down on the screwdriver until it pops off.
Once the chrome ring is detached from the knob, place a flathead screwdriver in-between the slit of the knob and turn the screwdriver to spread the slit, then pull up on the knob and it should come right off.
Next slide the new t-shifter on and tighten the screw located in front of the shifter shaft with an allen wrench just enough to where its snug. Adjust the angle of the handle to your desire and finish tightening.
And thatís it. You can push the shifter back to park w/o pressing the red tab down.
Old 02-12-2010, 06:18 PM
topgun's Avatar
topgun topgun is offline
Vehicle: 2012 Ram 2500 CC 4X4
Trim Level: Outdoorsman
Rep:71
topgun will become famous soon enough
Looks really good!
What purpose is there to using the red tab? I've had mine off but didn't have to do that?
Undercover SE, Corsa Cat Back, Amp Powersteps, Amp Bedstep, Bedrug, Mopar Tailgate Lock, Mopar Fold Flat Floor, Mopar Flat Rubber Splash Guards, Cooper AT3 285/70/R17's, S&B Intake, Moroso Catch Can
Old 02-12-2010, 06:23 PM
MADDOG MADDOG is offline
Rep:22
Nice work!!!
Old 02-12-2010, 07:23 PM
marko7717's Avatar
Rep:92
Originally Posted by topgun View Post
Looks really good!
Thanks.
Iím not sure. I guess you could take off the old one and install a new one w/o moving the shifter. Unless you are a clumsy one, and would wind up smacking the HVAC controls.
Old 02-12-2010, 07:27 PM
griff43's Avatar
griff43 griff43 is offline
Vehicle: 2009 Dodge ram 1500
Rep:87
griff43 will become famous soon enough
Looks awsome,just got off the phone with my dealer they have 2 in stock so it will be on tommorow!
2015 power wagon 6.4 stock for now
Old 02-12-2010, 08:58 PM
I push the skinny pedal
Rep:3277
Looks awesome, and a great write up too.
Kurtis
Old 02-12-2010, 09:03 PM
MightyBlueRam's Avatar
MightyBlueRam MightyBlueRam is offline
Vehicle: 2014 Ram 1500 EcoDiezl Laramie
Trim Level: Laramie 4x2
Color: Blue Streak Pearl Coat
Rep:432
MightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really nice
Excellent write up and nice photos.
Old 02-12-2010, 10:03 PM
Big Daddy's Avatar
Big Daddy Big Daddy is offline
Vehicle: 2009 Crew Cab / 3.92 rear end
Trim Level: SLT Big Horn
Color: Stone White
Rep:917
Big Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to behold
Nice job! Looks great!
Big Daddy
Marching to Mamasita's beat for a real real long time...
____________________
Dennis
Old 02-12-2010, 10:13 PM
Indeepcamo's Avatar
Indeepcamo Indeepcamo is offline
Vehicle: 2010 2500 Mega Cab
Rep:30
Indeepcamo is on a distinguished road
That looks great, too bad the shifter on the 2500 is only on the column even with the bucket seats or that would be going in my truck
Old 02-13-2010, 11:49 AM
topgun's Avatar
Rep:71
Originally Posted by marko7717 View Post
Thanks.
So the button releases the shifter without the your key?
