MOPAR DECALS
Old 02-13-2010, 02:44 PM
CHADDER03's Avatar
CHADDER03 CHADDER03 is offline
Vehicle: 2009 Ram Quad Cab
Rep:29
CHADDER03 is on a distinguished road
Thanks a lot for all the info, the truck seems to be running fine and the mds kicks in and out as it always has and I havent noticed any mpg loss. The only thing I have noticed is before the oil change when I started it up there would be a small puff of smoke that would come out and now nothing. When I had it changed it was down a litre and I have aprox 4000kms on it now since the oil change and it is not down a bit. The problem with causing a stink at the shop is the mechanic is a buddy of mine and he owns the shop. So causing problems really wouldnt be a good idea for me, he recommended that I change it every 7500km and I'm over half way there so I might just wait and have him put the proper oil in next time?
Old 02-13-2010, 02:55 PM
Zekery360 Zekery360 is offline
Vehicle: 2002 Dodge Ram
Color: Bright Red
Zekery360 is on a distinguished road
I would change it now. It can only help at this point. Bring the truck to a Dodge dealer or do it yourself to make sure you are getting the right stuff, and good quality stuff. And just tell your buddy that you want your oil changed at a dealer so you get the right stuff. With modern engines the old "5-30 or 10-30" generalization doesn't work at all. Many engines are moving to a thinner weight oil, and for good reason.
will's Avatar
will will is offline
Vehicle: 2010 dodge ram quad cab
Trim Level: slt/bighorn
Color: silver
Rep:43
will is on a distinguished road
When i changed to synthetic i also noticed an oil puff. No big deal it will go away shortly. Well if you have an engine failure GOODLUCK getting warranty work done when you have the wrong oil in it.
OLD TRUCK
NEW truck soon to be here
Old 02-13-2010, 03:12 PM
Resident Technician
Rep:1915
I can guarantee an engine problem caused by incorrect viscosity oil in an engine won't be covered if they discover it. Speaking of lightweight oils, the V-10 uses 0W-40 synthetic and is factory filled with Mobil 1.
Old 02-13-2010, 03:30 PM
will's Avatar
Color: silver
Rep:43
True. If it is in the manual, go by it..
OLD TRUCK
Old 02-13-2010, 05:26 PM
eltoro2's Avatar
eltoro2 eltoro2 is offline
Vehicle: 2oo9 standard cab 4~4 1500 ram
Trim Level: plain
Color: pearl black
eltoro2 is on a distinguished road
my dealer said that 5/20 is recmemded as the new engene has closer tolerence , but I am thinking the more milage you put on it the more wear and looser tolerences . mine when started in morring I have a valve noise like a loose valve tapit . only have 10,000 miles on my hemmi 57 . what do make of that . curious ///
Old 02-13-2010, 05:30 PM
will's Avatar
Color: silver
Rep:43
Thats called the hemi tick. or so it has been called.
OLD TRUCK
Old 02-13-2010, 05:33 PM
Resident Technician
Rep:1915
I'd say you have the typical Hemi tick. Tolerances have nothing to do with viscosity. Race engines have super tight tolerances and run much heavier oils.
Old 02-14-2010, 12:18 AM
HoustonHemi's Avatar
HoustonHemi HoustonHemi is offline
Vehicle: 1492 Santa Maria
Color: Hot pink
Engine: 1981-1987 225ci (3.7L) Slant-6 95hp
Rep:135
HoustonHemi will become famous soon enoughHoustonHemi will become famous soon enough
[COLOR="DarkGreen"]I don't know for a fact that there have been any engine oil related 'failures' when using 'X'w-30 instead of 'X'w-20, but as they say, if there was a problem and they could pin it on the wrong viscosity, that would suck! As I understand it, the -30 'affects' the operation of MDS system,,,/COLOR]
I hear ya on pizzen off a friend,,, No reason to make a stink out of it,,, Just indicate 'next time' that Dodge will have a fit if ya use anything else, so you want to use it and see 'if it works' and to try and avoid any waranty related issues,,, If the guy is your friend, he shouldn't have a problem giving ya what you want, even if it isn't 'what he would use',,, Make "Dodge" out to be the reason,,, (My wifes 02 Accord uses 5W-20, so it's 'been around' for quite a while)
I think your Mechanic is right (in a way) when he indicates 'X'w-30 would give you 'more protection' than 'X'w-20. The 'heavier' oils would normally have a higher film strength, but here again, oils are sooo much better now than they were 20 yrs ago, and the MFG recommends it,,, The MFG is simply not going to recommend anything as critical as oil/oil change intervals that are going be detrimental to their product.
As far as when to go to 5W-20, IMHO, there is probably no major 'harm' done in waiting till 'next time', and certainly no harm done in doing it now.
Old 02-14-2010, 02:27 AM
CHADDER03's Avatar
Rep:29
HOUSTONHEMI---- thanks for the input, i belive we are on the same page. i havent noticed a change in any operation of the motor and at the price of synthetic oil i didnt really want to have it changed so soon. i think this is the reason behind why he did what he did: he services a lot of hemi's my old 03 included and with the 5w20 (no matter which brand) everyone of those trucks brand new and older all seem to burn through a litre (give or take), and not one of them has a leak. it also seems the guys who drive their truck a little hard myself included seem to burn through a little more. at my first oil change i was down around a litre. so im guessing he thought that maybe a heavier weight oil would protect a little better and maybe not burn up as easy, and as far as not burning as quick he is right ive put 4000kms on since it was changed and my oil level hasnt drop a cm on the dipstick. as for the fuel econ and the mds nothing has changed the mds kicks in and out exactly the same as it always has and my fuel econ hasnt changed at all during normal driving conditions. my next change i will forsure be putting in 5w20 just to keep things on the up and up, now i dont know forsure that that is the reason but its my best guess. as far as damage to the motor i personally cant see that, keeping in mind i am not a mechanic nor do i claim to be but i do have a pretty good grasp on things and i do a lot of my repairs and modifications myself. that being said i think his heart was in the right place, it may not have been the best idea but... im not goin to hold it against him. i know he would never knowingly do something to my truck that would damage it.
